16 ft Jumbo V summer project
water bouy
Post by water bouy » 22 Aug 2017, 12:55
Got a few pieces covered and one hatch installed. Weldwood contact cement seems to work well with vinyl.
The Nikon digital camera I use suffers from "barrel distortion" which warps everything. The hatches are going on top.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
water bouy
Post by water bouy » 27 Oct 2017, 21:18
The boat project has slowed to a crawl between work and chasing whatnots. It's rated for a 40 so I looked around for the lightest one I'm aware of and turned it into a tiller.
Duke62
Post by Duke62 » 28 Oct 2017, 08:41
Looking good. I like the vinyl and cosidering using some on my build.
United States Air Force (Retired)
1973 Seacruiser 14 ft conversion (glass) http://www.tinboats.net/forum/viewtopic ... 21&t=28559
1985 Bass Tracker Refurb https://www.forum.tinboats.net/viewtopi ... 28#p440638
water bouy
Post by water bouy » 30 Oct 2017, 23:10
Thanks Duke. I like vinyl and aluminum composite panels. Even though they cost more up front you only have to do it once.
That electric start 40 Mariner weighs 160 lbs on my bathroom scales. Wish I could say the same.
water bouy
Post by water bouy » 03 Nov 2017, 10:42
The rear bench sits so low there's no way to get cables under it to the batteries up front so I'm thinking of a 1 1/4" hole all the way through it and run wiring inide the compartments. It needs the battery cable, trolling motor cable, light wire and fish finder wire. I'll pipe through the bench and bush each end unless there's a reason not to do it. I'm guessing it wouldn't compromise the strength of the bench?
DaleH
Post by DaleH » 03 Nov 2017, 12:51
water bouy wrote:I like vinyl and aluminum composite panels. Even though they cost more up front you only have to do it once.
Ditto ... marine vinyl is AWESOME! My rig is 20-years old this year and after a good pressure washing ... it looks like new!
#4 Procraft SV14
water bouy
Post by water bouy » 09 Feb 2018, 16:01
Today felt like spring so I uncovered the boat and cut two pieces for the front benches and one for the bow. Last year I rattle canned the inside a white color to keep it cool in the sun. This project may be ready by the time I'm too old to fish. So far I bought 4 sheets of 6mm alum composite panels weighing 45 lbs each, almost identical to 1/2" plywood. A good thing on such a light boat.
ncfishin
Post by ncfishin » 09 Feb 2018, 19:45
Looks good bud. I got a lot of things going on too. Priorities, right. Good to see you got the cover off the boat.
water bouy
Post by water bouy » 10 Feb 2018, 13:48
Thanks, nc. I think working on it is almost as much fun as fishing.
The deep cycle battery is going up front but I'm debating where to put the starting battery. Side by side would be ideal to counter the weight in the back.
Came across a good tutorial on wiring but no charger is mentioned.
https://newwiremarine.com/how-to/wiring-a-boat/
Minn Kota makes an on-board charger that looks good.
https://www.amazon.com/MinnKota-Board-B ... g=pda0e-21
water bouy
Post by water bouy » 16 Feb 2018, 14:58
Cut a piece this morning and mocked it up before the rain got here.
Been making rod holders out of a piece of starboard I got off ebay.
water bouy
Post by water bouy » 04 Mar 2018, 17:23
Doubled up on the panels for the front hatch. The lift support works better than expected.
https://www.amazon.com/Apexstone-22-5lb ... 6YSGQSRCGC
I hope the fish appreciate all this work.
Post by richg99 » 04 Mar 2018, 18:41
Heck with the fish, I appreciate all of your hard work.
Nice.
gatorglenn
Post by gatorglenn » 05 Mar 2018, 03:59
Me too, looking great
water bouy
Post by water bouy » 05 Mar 2018, 23:08
Thanks guys. I just hope the fish don't move away before it's done.
Today I cut in a vertical hatch to use all that space under the bow. Been looking around for a bow light and socket without much luck. Those stick-on strips looked good and then found out they're not approved by the coast guard I guess. It needs to be the post type higher than the trolling motor.
Post by richg99 » 05 Mar 2018, 23:24
Re "Barrel distortion". Pretty much every camera, other than "view" cameras, have that issue. Don't worry about it.
Most people who view digital pictures are so used to it that they don't even see it.
