It is currently 24 Jan 2019, 01:07
AirboatCoatings
 Page 1 of 1 [ 5 posts ]
 Post subject: Steering box - Clip
PostPosted: 19 Aug 2017, 13:47
Was under the console fixing a crack and I saw this. Does the clip look correct or should it be pushed on further?
PostPosted: 19 Aug 2017, 21:37
Looks fine to me! Where the 'curl' of the turn is, it's sitting right in the recess for it.
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#2) 25' Parker refurb from EMPTY hull http://www.classicparker.com/phpBB3/vie ... p?f=15&t=6
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
PostPosted: 20 Aug 2017, 08:17
Thanks for the info.
PostPosted: 20 Aug 2017, 11:16
Going from memory. It's not a clip. It's a push pin to release the steering cable. They have you shove it There for storage until you need to remove the cable then you push the end of the pin in a hole to release the cable.
1991 18' Valco Bayrunner Evenrude 48 SPL
Arizona
PostPosted: 21 Aug 2017, 14:56
We learn sumthin new everyday.
Tim
16ft 1989 Fisher SV-2 w 1988 48hp SPL Johnson "CIGAR BARGE"
(engine looks like a wreck but runs great)
Used to have 1972 14ft Lund w 1977 15hp Mariner
(engine looked great but always ran marginal)
XLINE SPORTSMANS CLUB
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 83 guests
BoatCoversDirect
