Impeller polishing
Xpress165
Impeller polishing
Post by Xpress165 » 11 May 2019, 15:50
Anyone have their impeller polished and any shoe work done? Saw a guy on Facebook river rat pump worx that does it. People claim they get 2-3 more mph having it done. Just trying to squeeze anything more out of my 2017 merc 60/40 4 stroke. Thanks!
Impeller polishing
Post by BigTerp » 13 May 2019, 10:04
I've never had it done, but I've read from a few that have that there was no noticeable difference. I can't imagine it would last very long either, especially if you're running in anything sandy. If you're running an aluminum impeller, stepping up to a stainless will get you noticeably better hole shot and an increase of a MPH or two on the top end. Seems to be what most experience going from aluminum to stainless including myself on a 1994 Johnson 50/35.
onthewater102
Impeller polishing
Post by onthewater102 » 13 May 2019, 12:20
I've got some magic beans that will give you another 10 mph if you put them in your fuel tank... :twisted:
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
handyandy
Impeller polishing
Post by handyandy » 21 May 2019, 11:23
haha :LOL2: I haven't done it to mine as I figured a really good polishing would be reuined the first time I suck any sand or gravel. I have taken my housing off and used a dremel and 90 deg air grinder with sanding heads to get rid of the bad casting imperfections. I'm sure having a polish job helps some might be good for 1-2 mph. There isn't much you can do outside of it to try and improve that motor other than trying lighten up your boat or load you have in it.
AK80
Impeller polishing
Post by AK80 » 21 Oct 2019, 18:09
2-3 mph on top... seems to show more at cruise. I had my impeller done by said shop above. 29-30 mph @ 4800 rpm 6.3 GPH, 39.5 WOT 5800 rpm on still water with polished impeller. Merc 80 jet 4S, 17.5 Almar Lite. I have been fortunate to keep it clean so far, I'm sure it won't like any gravel. Don't really plan on looking for any
handyandy
Impeller polishing
Post by handyandy » 11 Nov 2019, 10:48
I'm usually not looking for gravel/sand but my main river when it gets really low late summer/early fall is when smallie fishing is best, and some riffles it's unavoidable to get through sucking up some. Like I said the polishing can help, I haven't bothered with spending the time to do it or spending the money on having a really good job done, but my pump did have some pretty rough casting marks/ridges I smoothed out some to at least get rid of the real stuff that definitely wasn't helping water flow.
