Has anyone ran the 4S SS impeller in a 2S
I have a new-to-me 95 Merc 45 Jet with the stock aluminum impeller. I sharpened up the impeller, which had been severely defiled
. It runs great but I wanted to get a stainless impeller for it. I didn't know the whole 4S cutback to the 2S impeller under the same part number. I ordered a new stainless impeller and I'm guessing it's the 4S style now. I don't want to run it if I may lose holeshot or over rev the engine with no added MPH. I'm very happy with the performance right now. I was thinking about returning the SS and just getting a new aluminum one from OBJ. I'll attach a picture of theimpeller if anyone can confirm that this is the 4S model, thanks.
1860 SeaArk MV Mercury 60/40 Jet
1648 Tracker Grizzly Mercury 60/45 Jet
1648 MonArk 50/35 Evinrude Jet
1444 Polarkraft 50/35 Evinrude Jet (Stick Steer)
I haven't run the 4S impeller in a 2S motor so I don't know how it would perform, but I can identify your impeller for you. It's the 4S impeller. Below is the 2S & 4S side by side. 2S on the right.
Don't know if you would be interested, but I have a Wooldridge 4 blade SS impeller for sale in the Classified section.
2011 Lowe Roughneck 1655CC - 2008 Mercury 2 Stroke 90/65 (Converted from prop 90)
buy a cheap tachometer off ebay and try it if it revs to high sell it rotus on here might buy it I know he has a 4s and might want a SS impeller for it maybe. I'd be curious to know how it runs on a 2s
Hah, thanks Andy, you are darn right, I'd consider it if the OP doesn't want it.
Did you try running it yet?redrum wrote:I have a new-to-me 95 Merc 45 Jet with the stock aluminum impeller. I sharpened up the impeller, which had been severely defiled. It runs great but I wanted to get a stainless impeller for it. I didn't know the whole 4S cutback to the 2S impeller under the same part number. I ordered a new stainless impeller and I'm guessing it's the 4S style now. I don't want to run it if I may lose holeshot or over rev the engine with no added MPH. I'm very happy with the performance right now. I was thinking about returning the SS and just getting a new aluminum one from OBJ. I'll attach a picture of theimpeller if anyone can confirm that this is the 4S model, thanks.
No, not yet. I'm currently working on a Wetlander 3L kit.handyandy wrote:Did you try running it yet?
- Lil' Blue Rude
The 4 stroke impeller will be fine in your 2 stroke. Might even be better considering you have the 52cube merc. I've got a friend with a 56cube omc and he's running a 4 stroke impeller and there's not much difference rpm wise maybe 200rpm nothing crazy that's going to over rev a stock motor. Plus the stainless will last way longer then the aluminum ever would.
16' 42" Blazer SS with a custom short shaft 60/40 Evinrude
The results are in:
Aluminum 3 blade Impeller - 29.7 MPH @ 5,400 RPM
Stainless 3 blade 4S Impeller - 30.0 MPH @ 5,300 RPM
Not the results I expected but now I know.
I'm surprised that you got higher RPM with the aluminum 2S impeller than the SS 4S. When I first got my Mercury 4S 40 Jet, I tried both the 2S SS and the 2S aluminum impellers. I got around 4900 top end RPM with both. With the SS 4S impeller, I get around 5200 RPM. Guess the 4S just doesn't have enough power to turn the 2S impeller any faster.
All good information, it would seem that redrum got one of the old style ss impellers.
Don't think so, the photo that he posted shows a new 4S type impeller.mphelle wrote:All good information, it would seem that redrum got one of the old style ss impellers.
I think my aluminum impeller is original. It has been ground on for sure. Here they are side by side. I bought the SS one new just last month. Im pretty sure it's the 4S model.
Hoping rotus will buy the SS one from me and I'll get that 4 blade from Larry then post the results.
Gotta say I'm extremely happy with the upgrade from the 50/35. Just better overall performance and the 3 cylinder sounds good
redrum, if your new impeller is still out, could you post a photo of it laying on it's side with the same orientation that LarryMc used in his photo. Thanks
It's still in the pump now. It is in the first picture up top. Here are a few more pictures I have of it.
No problem, LarryMc shows impellers from two different suppliers and it's easy to see how much material has been removed from Merc's new casting.
