It is currently 23 Jan 2019, 12:02
VinylImagesInc
 Page 2 of 2 [ 29 posts ]  Go to page Previous  1, 2
PostPosted: 22 Aug 2016, 11:19
Tbradley wrote:
RiverBottomOutdoors wrote:
PT&T on my 60/40. I also have a flatbottom tunnel hull. My foot has taken a few licks. When I'm at risk for an impact I trim all the way down because I want the leading edge of the foot tucked in. Don't think I would ever give up PT&T.
Seems to me you'd want to trim out so the foot would be higher?
You have to remember that trim works on a pivot so when you trim the motor up it actually swings the leading edge down. Also trimming the motor up moves the foot further away from the hull creating a gap that can cause your foot to hang logs etc that you slide over. You don't want to take a lick on the leading edge of the foot, that will cause severe damage to the foot and most likely your transom.
That's my take on it anyway. :-)
Jonah
www.RiverBottomOutdoors.com
Facebook
https://www.facebook.com/RiverBottomOutdoors
My Boats:
1656 CCJ http://www.tinboats.net/forum/viewtopic.php?f=21&t=29361
1448 MV http://www.tinboats.net/forum/viewtopic.php?f=21&t=15412
PostPosted: 22 Aug 2016, 22:10
Everything dhoganjr said!!!! He is right on imo. I have owned 3 flat bottom jets and run them in south Missouri. All tiller boats. First two were non power trim and really thought they were the way to go. Have had a Mercury 60/40 tiller now for a year and dang what a difference. Love power trim. Nice little button on the end of the tiller made for your thumb, my hand is there anyway. Would hate to not have power trim now. As stated above, when trimmed, u hit the back half of the shoe. I have hit twice now and only thing with some rock scratches was at the very back.
PostPosted: 23 Aug 2016, 10:09
I was hoping you'd see this thread being you have the exact motor setup. So you don't worry at all about taking a hit driving the tiller with the motor locked down?? I can see all the benefits of the power tilt/trim it's just the fact it's locked. Do you know if you did hit bad enough would the motor kick up?
PostPosted: 23 Aug 2016, 12:21
I run on clear rivers with mostly gravel bottoms, so the worse I have done is suck up some rocks and dulled the impeller. I am a more experienced operator now than I was and generally only go where there is plenty of water, it's skinny in places but it's just gravel. I don't worry bout it really. I have insurance and not sure I want that big motor coming towards me or tiller bar smacking me. Don't know if it would kick up or not, haven't hit anything and hope I don't.
PostPosted: 24 Aug 2016, 10:27
[/quote]I run on clear rivers with mostly gravel bottoms, so the worse I have done is suck up some rocks and dulled the impeller. I am a more experienced operator now than I was and generally only go where there is plenty of water, it's skinny in places but it's just gravel. I don't worry bout it really. I have insurance and not sure I want that big motor coming towards me or tiller bar smacking me. Don't know if it would kick up or not, haven't hit anything and hope I don't.
Sent from my iPhone using Tapatalk[/quote]
See that's the thing. My rivers aren't that clear, just mainly in the riffles where it's shallow. We have large rocks all the way down to gravel and sand. I've had the tiller bar on my 25 Merc hit me a couple times, then I learned to sit to the side of it on the rear bench so it couldn't get me or my knee. I sit straddling the rear bench, much easier for me to drive that way. So you can see for my questions on the gas assist vs power tilt/trim.
PostPosted: 24 Aug 2016, 20:39
Oh I fully understand your reasoning for your questions. The truth is I haven't hit anything. At the lake I don't worry bout hitting anything. I run couple of different rivers and there are big boulders but I can see them. The river I run the most the shallow spots are gravel. I glad to have power trim. Did not have it on other motors I have had so when I bought this one it had it and I love it. If my new motor would not have had I still would have purchased it.
PostPosted: 25 Aug 2016, 09:39
There are times when I'd like power trim for being able to fine tune for speed when I'm running a open stretch. But the kick up of the gas assist saves my intake a lot of times when hitting logs or rocks has been unavoidable. I've switched to a rock proof intake for more insurance I like it so far it takes a hit pretty well. I've had my motor kick up on me plenty when I've slid over a log or hit something I've never had my tiller hit me. But then again I have a storage box going along the side of my boat that I sit on so I'm not in the middle.
PostPosted: 30 Aug 2016, 14:18
Well a call to Mercury about the specs on their website has proved there is a misprint. The person I talked to told me the Merc 60/40 jet only comes with power tilt/trim and I double checked on their brochure online and it states power tilt/trim only.
PostPosted: 30 Aug 2016, 20:03
My guess is, once you run it and get used to the power trim, you will wonder how you ever got by without it.
My boat is heavy and I have had it since August 2002. In that time I have busted 2 shoes. The first one was on the 115 running at night when I hit some chunk rock. The second time was with the 250 on the big rock on my video, it was a sideways hit. I have had numerous straight on hits over the years, rocks, stumps, and logs, several hard hits. Most times it will just scrape off paint, put a small gouge here or there, and bend the grates.
Running shallow you will take an occasional hit, but if it is set up right most times it will slide on over like it is designed to do. Those shoes are tough, mine has 500 lbs of motor weight setting on top of it.
Dan
2003 1860 Alweld Flat Bottom
2014 Mercury 250 Pro XS Jet
2003 RiverCraft trailer
Retired from Riverlife-2002 Mercury 115 Fourstroke Jet
PostPosted: 01 Sep 2016, 22:13
Agree to all this.
PostPosted: 01 Oct 2016, 05:36
With gas assist and not having a tiller to help with pulling on a 60/40 Merc is tilting up to clean the grate a bear? Can you do it just by pulling on the cowling or is that too much work too often on some rivers where stuff gets clogged often? I like the idea of the motor kicking up but not all the way into the rear deck passenger. Does the built in impact assist on the Merc power T & T really help with hard hits without the motor coming up too far as it seems can happen on gas assist and let you get to the shoe for cleaning a lot easier plus all the fine tuning benefits? Sounds like the best compromise having never seen one but wanting this particular motor for next rig. I assume the factory set back is a lot less than an aftermarket power unit....is that accurate? On a custom boat is there an ideal transom height for this motor on a tunnel hull for getting the most out of fine tuning?
PostPosted: 01 Oct 2016, 10:34
I weigh 150 lbs and have a short shaft 60/45 Mercury 2 stroke and I had to put both feet against the transom and then pull up on the cowling(hood) to tilt it up and lock it. It wasn't that big of a deal since the gas assist would help once you got started tilting. Once in a while, if I wasn't paying attention it would come up short and then go back down and tilt me up. I'm not sure how much the gas assist absorbs an impact, I have a tunnel and I've never hit anything.
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
1993 Jetcraft 13' sprint boat with Chevy ZZ3 350 engine and Hamilton 772 jet drive
Online
PostPosted: 01 Oct 2016, 19:31
Sounds like gas assist is not an option anyway oo it's power for me plus I know that four stroke outweighs your two. I'm glad riverbottom clarified that caused it struck me as opposite too till I read his reasoning. How many of you guys are using aftermarket poly shoes and can you still get one for the 60/40 Merc? Seems I read the guy making them stopped.
PostPosted: 06 Oct 2016, 15:18
I have one of the rockproof UHMW intakes I bought only a few months ago you just have to call rock proof boats might have to leave a message or try again. They aren't a huge shop with someone at the phone all the time. I have a older 60/40 two stroke merc. The four strokes still use the same outboard jet as the old ones they just have a different drive shaft too fit the four strokes so my extra AG model outboard jet I have for parts I could buy a new drive shaft for it and bearing rebuild kit cause it would need to be used again put the new stuff in it and it could go on a new four stroke. So the rock proof intake should work on your four stroke. I don't know where abouts you live but if your close or ever close to me you can check mine out.
Users browsing this forum: No registered users and 13 guests
SliderG5
