Jet john
Paintman
2
Jet john
Post by Paintman »
Not sure on either yet,got it flipped back over
huntinfool
Jet john
Post by huntinfool »
Paintman wrote:Looks like factory
Come on Granger! About ready for a test run.
Sent from my XT1585 using Tapatalk
Paintman
2
Jet john
Post by Paintman »
I'm using a Kawasaki 750 as motor and was wondering if I could attach a waterhose to the intake hose so I could test run at home,also where should I run my exast,out the bottom or out the back?
flex
2
Jet john
Post by flex »
Paintman wrote:I'm using a Kawasaki 750 as motor and was wondering if I could attach a waterhose to the intake hose so I could test run at home,also where should I run my exast,out the bottom or out the back?
Yes to the hose. Just don't rev it to much. I would run the exhaust out the back. So if it leaks you don't sink and it's an easy fix. Make one of those pee streams too!
Sent from my HTC One M9 using Tapatalk
CedarRiverScooter
5
Jet john
Post by CedarRiverScooter »
Not sure about a Kaw, but on Polaris you are supposed to start the motor 1st then turn on garden hose. Apparently water can backflow thru exhaust ports if motor isn't running 1st.
I'd get the exhaust to be as low as possible, as it will be loud. Make sure it routes above max waterline, so it can't siphon water.
Paintman
2
Jet john
Post by Paintman »
I'm thinking about using a flexible radiator hose for the exhaust, the rubber hose from the ski won't work,what says the jet john guru's
CedarRiverScooter
5
Jet john
As long as it is same diameter, should work. It doesn't get very hot since it is water cooled exhaust.
Paintman
2
Jet john
Post by Paintman »
Got the exhaust run tonight,and fired it up,need to rebuild the carb,only way it would fire was pouring gas down the carb,can anyone post a pic as to where all the hoses go,
CedarRiverScooter
5
Jet john
'Green Hulk' is a great website for PWCs. They will have the info you are looking for. I got a shop manual for my Polaris, that is very helpful.
On the carb rebuild, get an OEM kit, the aftermarket ones are junk. Consider a new fuel pump. It it goes lean you will burn pistons up.
Paintman
2
Jet john
Post by Paintman »
Motor is running good,started on the rear deck tonight
Paintman
2
Jet john
Post by Paintman »
Little more work,seat area is removable along with the deck
Paintman
2
Jet john
Post by Paintman »
Struggling with steering,any help
flex
2
Jet john
Post by flex »
Paintman wrote:Struggling with steering,any help
I think most of the converted jet boats I've seen use a "stick steer" like an air boat.
Paintman
2
Jet john
Post by Paintman »
Ya I didn't wanna do a stick steering
CedarRiverScooter
5
Jet john
Are you going to use jet-style 135 degree helm?
https://www.wholesalemarine.com/telefle ... wAodr8UBNg
You might have to get a custom cable too.
