Page 3 of 7
Jet john
Posted: 08 Feb 2017, 10:59
by SC Designs
Yo Paintman, check out my latest build I just posted. I seal everything with 3M 5200 and stainless screws then come back over it with fiberglass and bondo for smoothing.
Jet john
Posted: 08 Feb 2017, 22:46
by CedarRiverScooter
I also used fiberglass filler for smoothing. I recommend epoxy resin for the fiberglass filler. Polyester can absorb water & has less adhesion to boot.
Jet john
Posted: 08 Feb 2017, 23:17
by stinkfoot
What happens when you nail a rock with the Bondo?
Jet john
Posted: 09 Feb 2017, 09:13
by SC Designs
The bondo is very small amounts, basically when the glass is laid it still creates and uneven surface so after sanding you still have high and low spots, that's where the bondo comes in. Its not large amounts to fill up huge holes. It's a given if a person smacks a huge rock, no matter whats under there on the hull, it stands the possibility of doing damage. I personally try to stay away from the rocks...lol.
Jet john
Posted: 12 Feb 2017, 01:50
by Paintman
Little work done
Jet john
Posted: 12 Feb 2017, 18:05
by Paintman
More progress
Jet john
Posted: 12 Feb 2017, 18:34
by Paintman
Some more pics
Jet john
Posted: 13 Feb 2017, 09:09
by SC Designs
Looking Good !!! =D>
Jet john
Posted: 13 Feb 2017, 14:02
Great job!
Transition panel should work good to avoid cavitation.
Jet john
Posted: 21 Feb 2017, 02:11
by Paintman
Jet fitted
Jet john
Posted: 22 Feb 2017, 20:57
by Paintman
Little work
Jet john
Posted: 22 Feb 2017, 23:36
by flex
Hey buddy! Haha. I also joined to post my build!
Sent from my HTC One M9 using Tapatalk
Jet john
Posted: 22 Feb 2017, 23:39
by Paintman
Awesome,what r u building
Jet john
Posted: 23 Feb 2017, 10:42
by handyandy
So are the pump housings on those jet skis composite with a metal wear sleeve in them?
Jet john
Posted: 23 Feb 2017, 20:58
by Paintman
No all composite,the jet is aluminum
