It is currently 17 Jul 2018, 11:15
 Page 3 of 4 [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Changing out Mono
PostPosted: 06 Dec 2017, 16:24
Not sure if braid has changed much since I switched back to mono years ago, but I had issues with the abrasion resistance of braid. I fish for smallmouth in a rocky river and 95% of my fishing is bottom fishing with soft platics and jigs. I found that braid didn't stand up well to being constantly rubbed against and pulled through rocks and hard bottoms. I now use Yo-Zuri Hybrid and love it. But I still use braid on a round reel I have for froggin' and top water.
BigTerp's Tracker Sportsman 16' build-------> viewtopic.php?f=21&t=26774
 Post subject: Re: Changing out Mono
PostPosted: 06 Dec 2017, 18:56
I learned to tie the FG knot from this video: https://youtu.be/pjzUb5QRKuk
With a follow up tip from this video: https://youtu.be/LD1gWbp9zKo
Those two together made it pretty easy to learn.
PostPosted: 11 Dec 2017, 17:17
BigTerp wrote:
Not sure if braid has changed much since I switched back to mono years ago, but I had issues with the abrasion resistance of braid. I fish for smallmouth in a rocky river and 95% of my fishing is bottom fishing with soft platics and jigs... I now use Yo-Zuri Hybrid and love it...
Hybrid is great stuff, but try it as a leader on a braid mainline sometime and you will get th3 beat of both worlds, sensitivity of the braid and durability of the hybrid at the end of your line. FG knot the hybrid on and you dont have to worry about passing the knot through even microguides on the cast.
For Sale - Custom Hand Tied Jigs, Bladed Jigs, Custom Rods
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
1985 Bass Tracker III - restoration posting coming soon w/ 1988 Mercury 60hp 2-Stroke & 55# Minn Kota Terrova 12v shared w/ my 14'
The way people should be
Online
PostPosted: 11 Dec 2017, 18:07
Onthewater....what Hybrid, please.
“That which is measured improves. That which is measured and reported... improves exponentially.
Karl Pearson"
Online
PostPosted: 11 Dec 2017, 18:32
Years ago, BB (Before Braid) I used to have to switch out the 6lb mono from my spinning reels sometimes twice a week when I was on a trip and fishing 12 hours a day. Spinning reels twist line and mono does not like being twisted. It would just get to be too much to deal with. I am 100% braid (never with a leader) these days but even though I fish rocky rivers, I've never had a problem with abrasion.
PostPosted: 11 Dec 2017, 19:10
What he said, and I've never used any kind of leader. I mark hi-vis yellow Power Pro (40#) with a black sharpie and go on......tag end, three feet.
My Tinny is a tool, a means to an end, if you will.
New River Smallies
Case Plastics Pro Staff
PostPosted: 11 Dec 2017, 20:36
By using a leader you keep the wear & tear of changing lures to the sacrificial tip - but you can also play with the leader material to better fit the lures you're presenting. Other than topwater presentations I don't use mono at all.
Hybrid - I was referring to Yo-Zuri Hyrid line - a co polymer blend of mono and fluoro that is tough as nails. I use 10lb test leaders of that stuff when salmon fishing in Pulaski NY, pulling 25lb salmon out of a rocky as hell 300 CFS flow river with water no deeper than 16" in many places. I've never had it break while fighting a fish. Great stuff.
Online
PostPosted: 11 Dec 2017, 21:31
Just ordered some. Thanks
Karl Pearson"
Online
PostPosted: 12 Dec 2017, 09:10
onthewater102 wrote:
This was another issue I had with using braid....the leader. I switched to a flouro leader because of the aforementioned abrasion issues but had issues with my leader to mainline knots. Don't remember off the top of my head what knots I was using, but I know it wasn't an FG knot. Might give the FG knot a try if I ever get the desire to go back to braid.
PostPosted: 12 Dec 2017, 09:32
Yo-Zuri Hybrid really is good stuff!! More sensitive than mono, great knot strength (I've never had a knot fail), excellent abrasion resistance, more sensitive than mono with some nice stretch/shock absorption, strength to diameter is great and a very castable line. It's priced right as well, IMO. So even though it's not needed I probably change my line out twice a year since it won't break the bank at $15 for 600 yards of 6# test.
PostPosted: 12 Dec 2017, 10:43
LDUBS, before I learned about lactic acid build up in stressing smallmouth, I used light tackle and 4# Trilene XL. I changed 1/2 spool for every reel, every trip. Overkill? Yes, but I had peace of mind and confidence built up before every trip. And, FWIW, I'm certain that UV and heat are mono's worst enemy.
New River Smallies
PostPosted: 12 Dec 2017, 12:30
I use Power Pro moss green on everything, and no leaders.
I re-tie when it gets nicks or tooth marks on the end. Not very often. I also reverse the line on the reel each year so I'm using it from both ends.
PostPosted: 14 Dec 2017, 01:58
Thanks. Same issue when releasing trout. Don't want to overplay them. I use 8# mono when trolling with down riggers. Otherwise, use 4# for tossing lures at trout. A lot of guys use 2#.
Have Rod - Will Fish
PostPosted: 26 Apr 2018, 11:53
I'd never even heard of a FG knot, nice to know. Have any of you found a way to tell when your mono is getting stretched too much? I don't fish with it a lot and this is a reason why I don't use it much. Nothing I hate more than getting a fish on and zing, there it goes!
PostPosted: 26 Apr 2018, 12:40
I can't ever remember having mono break. But when I used it, I was changing it a number of times every year.
I had lots of my bad knots come undone though.
I use braid now for almost everything except top waters. I usually use a Fluorcarbon leader with the braid.
Karl Pearson"
Online
Users browsing this forum: Google Adsense [Bot] and 7 guests
eaglelodgemaine
