Epoxy in the guide on my new rod
Questions or comments about your weapons, post away here.
juggernot
Post by juggernot » 01 Jan 2016, 21:20
There is a drop of epoxy in the guide on my new 7'6 H casting rod. It makes the inside of the guide have a slight flat space. It is the second guide from the reel and not on the rod side of the guide so I don't think it will ever have line pulled tight across it, but I'm wondering if the epoxy might crack/chip and harm the mono one day. Could I try to melt it off the Aluminum oxide guide or just leave it be? Thanks, Randy
jojo
Post by jojo » 01 Jan 2016, 23:48
If possible, I would exchange it for one that doesn't have this issue.
ProduceMan
Post by ProduceMan » 20 Mar 2016, 00:58
LIGHTLY heat the affected area with a heatgun or blow dryer. You want to heat the epoxy, not the whole guide and don't get the blank hot. Should then peel right off.
1973 Hewescraft Big Fisherman 14
1980 Johnson 15
“I love being alive and will be the best man I possibly can. I will seek knowledge from those wiser than me and try to teach those who wish to learn from me.” Duane Allman
Post by Captain Ahab » 20 Mar 2016, 07:18
If it is not changing anything just leave it. Tell your friends that it is a custom "fast cast" spot and helps attract fish
juggernot
Post by juggernot » 22 Mar 2016, 17:46
I was able to pop it off w careful pressure from my fingernail.
