Mounting plate help
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
ifish1002
Mounting plate help
Post by ifish1002 » 15 Sep 2018, 15:58
I have a bow mount motor on my flat bottom and I need some help into mounting it to some sort of plate as you can see from the pic there is nothing supporting. The back end underneath..please help if you can
eshaw
Mounting plate help
Post by eshaw » 16 Sep 2018, 10:00
Just have a piece of aluminum bent to hold up the back and bolt to the deck.
Mounting plate help
Post by richg99 » 16 Sep 2018, 15:49
If the already excellent suggestion of aluminum didn't work out for some reason, bolting a 2x4 with maybe another 1x4 on top should fill in the gap.
Bolt those to the boat and then lag-bolt the trolling motor to them.
Better yet, you could work some Stainless Steel T nuts into the sandwich of wood and bolt into it ...after the wood part is firmly bolted to the boat, of course. A little bit trickier to do, but would be better than lag bolts that will work their way out sooner-or-later.
Riverdog
Mounting plate help
Post by Riverdog » 17 Sep 2018, 18:05
Give Troutt and sons a call. I'm sure they will have what you need. https://trouttandsons.com/wp/
2013 1752 Blazer SS Mercury 60/40
Jump aboard, let's take a ride. <-clicky
ifish1002
Mounting plate help
Post by ifish1002 » 18 Sep 2018, 09:29
I have contacted alweld and they are sending me the trolling motor bracket now my real big question is what the best way to secure the bracket? Should I have it welded or use some type of screws?
Mounting plate help
Post by richg99 » 18 Sep 2018, 09:34
If you can reach underneath, bolting it would be my choice. If not, perhaps some Riv-nuts or expandable fittings will work.
Some smarter-than-I guys will soon comment.
rich
Riverdog
Mounting plate help
Post by Riverdog » 18 Sep 2018, 18:44
ifish1002 wrote:I have contacted alweld and they are sending me the trolling motor bracket now my real big question is what the best way to secure the bracket? Should I have it welded or use some type of screws?
I screwed my mounting plate. I think welding would be over kill.
MrGiggles
Mounting plate help
Post by MrGiggles » 18 Sep 2018, 21:56
Don't have it welded unless you're willing to paint the immediate area.
Personally I'd just pop rivet it on. Will never work loose, cheap, and easy install.
jethro
Mounting plate help
Post by jethro » 19 Sep 2018, 14:05
Yup, pop rivets would work fine.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
ifish1002
Mounting plate help
Post by ifish1002 » 03 Oct 2018, 06:26
Ok so I just received my motor bracket from alweld boats..when I placed the motor on top and positioned it so it hangs off a 1 1/2” off the gunnel it looks like the bracket is too long because when I took off the side plates to expose the mounting holes for the motor I can only bolt 2 of the last holes from the motor to the bracket..is that enough to hold it down?
Mounting plate help
Post by richg99 » 03 Oct 2018, 07:01
Just two bolts would not be enough for me.
From your picture, it appears that you are mounting the TM at a 90 degree angle to the gunnel. Is that so?
Most of my TM mounting has been somewhat parallel to the gunnel.
Anyhow, can you put some expanding nuts, or some RivNuts into the gunnel? That would give you more connection points.
Lastly, on a number of occasions, I've mounted a TM onto a plywood board using flush, Stainless Steel, T-Nuts. I then mounted that board onto the boat. Using such a "Transition Board" gives one a lot of additional mounting choices.
ifish1002
Mounting plate help
Post by ifish1002 » 03 Oct 2018, 13:12
It’s actually 2 bolts on each side that would hold the rear of the motor and for the front another 2 on each side also but I want to put the riv nuts on the gunnel because I don’t want to drill a single sheet metal screw into the gunnel..do I just buy any rivet gun or does it has to specific for rivnuts?
ifish1002
Mounting plate help
Post by ifish1002 » 03 Oct 2018, 13:13
Also the motor is not going on angle I’m mounting it straight up and down
ifish1002
Mounting plate help
Post by ifish1002 » 03 Oct 2018, 13:29
Would self drilling screws with loctite and a locking washer hold as well?
Mounting plate help
Post by richg99 » 03 Oct 2018, 14:19
I don't think that self-tapping screws would hold as well. This video may help you.
https://www.youtube.com/watch?v=I6H6wr7fJYo
