Installed a trailer hitch
Trailer related issues and discussion goes here.
lckstckn2smknbrls
Post by lckstckn2smknbrls » 13 May 2019, 21:40
I recently acquired my parents 2006 Toyota Sienna mini van, they bought it new and put 90,000 miles on it in 13 years. It's the limited XLE with almost every option but no hitch. I bought a Drawtite hitch over the winter but just got around to installing the hitch. The van has 6 threaded holes under the rear. I tried screwing the bolts in the holes but no go 13 years of northern Illinois weather, winters, salt and corrosion had messed up the threads.
I went to Auto zone and through their loan a tool program I got a thread restorer kit. I couldn't get the thread restorer to start in the threads either. My next idea was to use a tap to clear the threads. I went to Menards they had the proper size tap and the T handle too. It took about 15 minuets to run the tap through the 3 holes on the drivers side the holes on the passenger side were a little harder to get too because the tail pipe was in the way.
The instructions and most of the videos say to drop the exhaust but if you pull on the tail pipe and use a ratchet, long extension and 5/16" 12 point socket you can get the tap to the holes.
Now that the holes were cleared I slid the hitch in over the tailpipe and set the other end of the hitch on a floor jack and raised it up.
Now it was just a matter of screwing in the 6 bolts and torqueing them to 75ft pound and done. The hitch sits pretty low on the Sienna vans so I'll be getting a fairly tall hitch and I'll be using the Masterlock 1-7/8" 2" and 2-5/6" 10,000 pound rated interchangeable ball system.
All in all it went pretty well, I'm waiting for the trailer light wiring kit to come in.
FormerParatrooper
Post by FormerParatrooper » 14 May 2019, 18:37
I had the same Illinois issues when I added my hitch to my 2008 Saturn Outlook. It was a pain, I used cutting oil to retap all the holes. Fortunately when I traded that vehicle in for a 17 Dodge Durango, the hitch and lighting was already installed by the factory. I really wasn't looking forward to going under another vehicle to repeat that.
Only thing is I left my drawbar in the Outlook. Have to pick another up when the river comes down and I can get the boat out this year.
1979 MirroCraft F4604
1967 Johnson MQ13 9.5 Hp
1974 Evinrude 25452M 25 Hp
Life member of the LGOPPs
lckstckn2smknbrls
Post by lckstckn2smknbrls » 14 May 2019, 20:50
FormerParatrooper wrote:I had the same Illinois issues when I added my hitch to my 2008 Saturn Outlook. It was a pain, I used cutting oil to retap all the holes. Fortunately when I traded that vehicle in for a 17 Dodge Durango, the hitch and lighting was already installed by the factory. I really wasn't looking forward to going under another vehicle to repeat that.
I've installed 6 or 7 hitches and trailer wiring kits, most had issues of some sort even on new vehicles.
LDUBS
Post by LDUBS » 15 May 2019, 01:55
I installed a class III hitch on my previous pick-up. Probably a lot easier because I had plenty of ground clearance.
In addition to the wiring harness I had to get a heavy duty turn signal relay in order for the trailer lights to work. Basically plug and play, but I wouldn't have known had the guy at the auto parts store not said something.
Have Rod - Will Fish
enwez
Post by enwez » 15 May 2019, 13:00
Our boats are pretty light, so maybe not necessary but look into installing a transmission cooler. I think they're <$100 and not to hard to install.
Luckily for me the CD4E transmission is so notoriously unreliable Ford already installed one stock on my 08 Escape... #-o
lckstckn2smknbrls
Post by lckstckn2smknbrls » 15 May 2019, 15:03
enwez wrote:Our boats are pretty light, so maybe not necessary but look into installing a transmission cooler. I think they're <$100 and not to hard to install.
The 06, 07 sienna's have a trans oil cooler and an engine oil cooler and have a 3500 pound towing capacity. I believe starting in 08 Toyota did away with the engine oil cooler and lowered the towing capacity to 1500 pounds.
enwez
Post by enwez » 15 May 2019, 17:03
Looks like you're all set then!
FormerParatrooper
Post by FormerParatrooper » 15 May 2019, 19:24
For me it is just getting harder to crawl under there and do the work. Having it already installed was a major plus.
lckstckn2smknbrls
Post by lckstckn2smknbrls » 15 May 2019, 19:32
Getting down under the car is easy Getting back up is the hard part.
FormerParatrooper
Post by FormerParatrooper » 16 May 2019, 19:33
So true, I often wonder what happened to the years, there didn't used to be so many behind me.
LDUBS
Post by LDUBS » 16 May 2019, 22:19
Yeah, I thought it would take a lot longer to get this old!
lckstckn2smknbrls
Re: Installed a trailer hitch update
Post by lckstckn2smknbrls » 25 May 2019, 11:51
Update.
I installed a Tekonsha T-one trailer wiring kit. Installation was very easy and so far it works as it should.
