Submersible Lights
Trailer related issues and discussion goes here.
driz
5
Submersible Lights
Post by driz »
And don’t forget the dielectric grease on your plugs and connections. If you’re around salt or your rig sits out in wet environments it’s a must.....
"I'm only here for the beer and yes fishing sure beats working" 1985 Tracker V17 Tournament 50 Merc =D>
marshman
6
Submersible Lights
Post by marshman »
What’s the best system/method to route wiring? I usually just use zip ties.. the little clips never stay on and my trailer is box tube..
LDUBS
3
Submersible Lights
Post by LDUBS »
marshman wrote:What’s the best system/method to route wiring? I usually just use zip ties.. the little clips never stay on and my trailer is box tube..
Mine are pulled down the center of the rectangular galvanized tube framing. Rubber grommets are used where the wire(s) enter/exit the channels. This scores high for a neat look and does protect the wires, but makes it harder to inspect/maintain/modify. If someone wanted more access they could run them along the inner side of the frame members using a split wire loom & stainless wire clamps.
Have Rod - Will Fish
