Submersible Lights
Trailer related issues and discussion goes here.
chbarnha
1
Submersible Lights
Post by chbarnha »
What are the best wiring and light kits you have found for your trailers? I am about to order one and want to make sure I get one that will last> Thanks in advance
bcbouy
Submersible Lights
Post by bcbouy »
honestly,i don't think the universe wants them to last otherwise i wouldn't run over the plug with the jack wheel and crush the pins,back into a tree with the light and break the lense,vibrate them so bad they fall off or have an incandescent bulb pop as soon as i back it into the water,etc. but if you want it to last the season,go with a mid priced led.
if all else fails....stop using all else
chbarnha
1
Submersible Lights
Post by chbarnha »
thanks for the reply! haha sounds like the story of my life
Submersible Lights
Post by BigTerp »
LED is the way to go. I struggled with my incandescent for a season or two with bulbs bursting from being hot and hitting cold river water, and various other issues. Since switching to LED's and properly wiring them I haven't had a problem since. I don't even unplug when unloading/loading the boat.
lckstckn2smknbrls
Submersible Lights
Post by lckstckn2smknbrls »
I run the ground wire to each light.
Submersible Lights
Post by BigTerp »
lckstckn2smknbrls wrote:I run the ground wire to each light.
This!!
mbweimar
Submersible Lights
Post by mbweimar »
I bought a set of Peterson LEDs on Amazon 5 years ago. Peterson manufacturs a lot if lights for semi trucks and trailers. I should also mention that in use my boat exclusively in salt water and gets dunked at least once a week.
2013 Weldbilt 1752V
ETEC E40DSLSE
Riverdog
4
Submersible Lights
Post by Riverdog »
As mentioned above, LED is the way to go. More expensive, but last much longer.
2013 1752 Blazer SS Mercury 60/40
Jump aboard, let's take a ride. <-clicky
sportsman
1
Submersible Lights
Post by sportsman »
I found what appears to be a really nice wire loom for trailers at Harbor Freight in Mountain Home, Ar. I bought all my LED lights at R&P Carriages, online through eBay . I no longer unplug when launching or loading. And they work. IMO LEDs are the way to go.
kofkorn
Submersible Lights
Post by kofkorn »
This!!
I do this to every set I install...
LDUBS
3
Submersible Lights
Post by LDUBS »
I have LEDs but still unplug the trailer before I back it down the ramp. Just habit at this point.
Have Rod - Will Fish
CedarRiverScooter
5
Submersible Lights
Post by CedarRiverScooter »
LDUBS wrote:I have LEDs but still unplug the trailer before I back it down the ramp. Just habit at this point.
The hard part about that is remembering to plug them back in!
LDUBS
3
Submersible Lights
Post by LDUBS »
Truer words were never spoken.
10sne1
5
Submersible Lights
Post by 10sne1 »
LEDs and always put them on my side guide posts. No more dunking them every time I launch. I also have a designated ground fron the frame of my truck to the frame of the trailer. Connect the two grounds with a plug.
Lakeland FL.
2006 Triton 1870 BaySport Aluminum
115 HP, Merc. 4/stroke
GYPSY400
Submersible Lights
Post by GYPSY400 »
I use LED lights from a semi-truck dealer ( truck-lite or Grote).. you can find all the connectors and what-not there...no need to buy a made in China kit.
Sent from my SM-G903W using Tapatalk
