It is currently 22 Oct 2018, 18:27
eaglelodgemaine
 Page 1 of 2 [ 26 posts ]  Go to page 1, 2  Next
PostPosted: 21 Aug 2016, 19:26
I'm doing my first trailer build and I figured I would put it all together on this tread. The trailer is very solid and is built like a tank. It's a tilt trailer which is something I love. Here is some before pictures.Image stripped down. Image
Because it's a tilt trailer the front trailer support could use some work and the previous owners used a composite wood post for a front support. I would like to change it to a wood bunk, so how would I mount it?Image
Another question for the on the pvc guides. It has the holes on a bracket of the side of the trailer. So can I drill a hole in a threaded pvc cap and bolt it to these holes or is it too much of a strain on the pvc?Image
The last question is the paint is in pretty good shape and under the paint it seems that it is galvanized and I got some self etching primer so there is no need to sand down to bare metal right?
PostPosted: 22 Aug 2016, 11:03
Let's see if we can help..
E-Trailer and Overton's have tons of different braces/brackets that will do the job. I imagine a simple carpeted 2x4 with the right bracket will fix you up. Of course, don't use treated lumber.
A PVC Cap will break the first time you put any side-load on it. I'd buy a 24/36 inch threaded steel shaft/ or/ a piece of galvanized pipe ( better) the same size as the hole. Put large fender washers and nuts on the top and bottom. Then, drop your PVC on that upright; drill large holes in the top cap (otherwise air pressure will float it off when you launch); and maybe run a light cord from the top of the PVC to the bottom support as a precaution to keep the PVC from disappearing.
If it really is galvanized, and some idiot painted over the galvanizing..I'd lightly wire brush it and re-apply galvanized paint over the top. Why anyone would mess with the best finish for trailers (galvanized) I don't know.
But, I am no paint expert. I'd re-post a simple question "Do I paint over old galvanized paint?" We have some true paint guys on here who can help more than I can. regards, welcome aboard
“Busy is a choice. Stress is a choice. Joy is a choice. Choose well.”.....Ann Voskamp
PostPosted: 22 Aug 2016, 11:08
Oh, while you are at it...you might also consider moving your tail-lights up onto the PVC uprights...to keep them out of the water.
Or, I usually just substitute new LEDs and leave them where yours are now. LED's solve the "immersion into water/bulb blowing " issues. richg99
PostPosted: 22 Aug 2016, 12:15
I got the new led lights. I guess I'll just keep the guides that I have already have.
For the paint I'm really wanting to paint the trailer because that will give practice when I go to my boat.
PostPosted: 22 Aug 2016, 12:26
Your boat, you can do what you want, and you should.
As I said before, though, we have some really good paint guys here.
Post a second thread with your paint (only) question. Someone will pipe in and help.
Even though it is a trailer question, I'd post it in the Boat House section. As it is paint related, I think that you will get a quicker response there.
Remember, some of these guys work, so you may not see an answer till this evening.
PostPosted: 22 Aug 2016, 15:37
Posting the question now. Thanks for your help.
PostPosted: 23 Aug 2016, 19:29
Got the bearing and hubs pulled off and I got one wheel sanded down and primed. BeforeImage afterImage primed Image
PostPosted: 23 Aug 2016, 20:48
Nice work...
PostPosted: 29 Aug 2016, 06:31
Got a little bit done over the weekend. ImageImageImageImage
PostPosted: 05 Sep 2016, 12:27
Got most of it painted. Just got to flip and paint the top side.Image
PostPosted: 05 Sep 2016, 19:32
Image just about got it done.
PostPosted: 05 Sep 2016, 20:11
Coming along..... Looks good. richg99
PostPosted: 13 Sep 2016, 05:49
Now I'm just waiting on the parts to build the new axle and it will be all done. I got it completely painted and started to put everything back together. Image
PostPosted: 13 Sep 2016, 08:09
Looks like new.
PostPosted: 19 Sep 2016, 21:46
Looks really good!
Sent from my SM-G935P using Tapatalk
Users browsing this forum: No registered users and 18 guests
VinylImagesInc
