Anyone able to suggest a good Compression Tester?
Rags2Fishes
Post by Rags2Fishes » 04 Sep 2018, 17:56
Hello, Thank you for the add to this forum.
I have been looking at Compression Testers and see quite a price variance. Can anyone suggest a good lower price tester for a basic Do it yourselfer?
I appreciate all replies!
Rags2Fishes
Finger Lakes, NY
KMixson
Post by KMixson » 04 Sep 2018, 18:12
I had bought one from Sears sometime around 1980 and it has lasted me this long. It is just a simple gauge with a hose and a couple of different adapters for the different thread patterns.
Weldorthemagnificent
Re: Anyone able to suggest a good Compression Tester?
Post by Weldorthemagnificent » 04 Sep 2018, 18:38
Mine came from Napa auto parts. Don’t spend the Farm on a snap on or other high dollar gizmo.
Rags2Fishes
Post by Rags2Fishes » 04 Sep 2018, 19:14
Thank you for your replies. I am still searching. I did look at Craftsman, my only thought is are they as good now as they were then. I see K-Mart and Lowes both sell Craftsman now. I know MAC and Snap-On are out of range as I'm not a shop. Harbor Freight's didn't have a good review.
Anyone offer the lifetime warranty like NAPA, etc.? Still open for more suggestions!
Rags2Fishes
Finger Lakes, NY
DS49
Post by DS49 » 04 Sep 2018, 20:43
If you are only going to use it occasionally and don't want to have one of your own, both Autozone and Advance have units you can borrow for free.
MrGiggles
Post by MrGiggles » 04 Sep 2018, 22:21
OTC makes some that are affordable, and are better qualtiy than what you'll find at most places.
I have a very inexpensive set from eBay, had them for almost 10 years and they still work fine. I hardly use them though.
A word of advice, if you plan to use it on small engines, get one that has a Schrader valve in the tip, right where it screws into the cylinder. If it is mid length in the hose, the volume of the hose adds to the volume of the compression chamber (lowering the compression ratio) and you will get false low readings.
86tuning
Post by 86tuning » 04 Sep 2018, 22:44
The snap-on gauge itself isn't that expensive. It's the box and accessory hoses that cost a mint. So if you only need ONE hose you can buy it piece by piece, and save a bunch of money for a quality gauge.
Thing that kills a gauge or any measuring tool is impact. So keep it in a box, and be careful not to drop it. Both of my snap-on compression gauges are over 20 years old, and work just fine. I have one at home, and one at the office.
I also prefer their torque wrenches.
The real question is, why do you think you need a compression gauge? Usually they are only useful for confirming that the jug is dead. Or checking an engine that doesn't run, before purchasing it.
Rags2Fishes
Post by Rags2Fishes » 04 Sep 2018, 23:25
86tuning wrote:The snap-on gauge itself isn't that expensive. It's the box and accessory hoses that cost a mint. So if you only need ONE hose you can buy it piece by piece, and save a bunch of money for a quality gauge.
Hi 86tuning, it would be for checking a few motors before purchase. I thought I would buy a couple of the same motors if possible to have spare parts on hand. I live in an area where there are many boats from fresh water lakes. Odds are good I'll find another! Plus I have some other things around where it might be good to have one handy. I live in a rural area and it might not be feasible to borrow one from Advance Auto or Autozone. They are both 25 miles each way and if I'm out on a "buy" maybe further. Thank you for replying.
Rags2Fishes
Finger Lakes, NY
Rags2Fishes
Post by Rags2Fishes » 04 Sep 2018, 23:32
MrGiggles wrote:OTC makes some that are affordable, and are better qualtiy than what you'll find at most places.
Thank you MrGiggles, I appreciate the advice. Will the description usually state there is a Shrader valve? Something I wasn't familiar with! My current Motor is a 1989 Johnson 40hp. Thank you.
Rags2Fishes
Finger Lakes, NY
Post by Weldorthemagnificent » 05 Sep 2018, 07:15
Unless you are wanting to use it on chainsaws and weedwhackers, an automotive gauge will work fine. Mine gives low readings on chainsaws but works fine on outboards down to 4 hp (smallest I’ve tried) snowmobiles, motorcycles etc. don’t overthink the gauge. If one reads 5lbs low or high is not a big deal, what you are looking for is the ability to spot two cylinders at 120 and one at 80. Great deals can be had on outboards that people don’t want to bother or have means to put on a stand and run in a tank and a compression test will tell valuable information. It’s a great tool and I recommend anyone who buys motors have one... a $40 one. My advice is to go with one from autozone or Napa. If you’re a small engine mechanic spend more. If you are into very small engines such as chainsaws get a specific gauge like an Oregon.
Post by Weldorthemagnificent » 05 Sep 2018, 07:19
Mr Giggles had a good point. The schrader (tire type) valve being right on the part that screws into the motor.
turbotodd
Post by turbotodd » 05 Sep 2018, 10:19
I have about 10 of them. If I take one engine and use all 10 gauges, I get 10 different readings.
All a compression gauge is good for is a general idea of the condition. If it says 10 psi on the gauge after doing a proper compression test, you have a problem. If it says 90+, it's generally going to be in good enough condition to run.
I see guys on FB all the time selling motors and they'll state in the ad that cylinder #1 has 133 psi #2 had 132 psi and #3 might have 134. LOL. Then I show up with my gauge and it says 120 and they start throwing a fit saying my gauge is junk. They'll run me off quick if I ask to see their gauge. "My mechanic tested it"...let's go to his shop then. LOL...99.99% of gauges out there don't read in 1 psi increments. Most are 5 psi. Typically if there's a compresison problem, it's obvious anyway. Like 20psi difference between cylinders or maybe the one only has 20psi.
The seal between the hose adapter and the cylinder/head also plays a big part...if it leaks, the gauge will read low...and not everyone takes good care of their adapter hoses and/or adapters.
The only true way to know an engine's condition is to do a leak down test. Better yet, pull the exhaust cover (on 2 stroke) and have a look at the pistons/cylinders-but not everyone will want to do that-and I understand & respect it. So I typically leak test them. Not real easy on 2 stroke stuff but it can be done. Real easy on 4 stroke stuff, especially pushrod 4 stroke stuff like lawn mowers. Pull the pushrods off and leak it, do not have to hold the engine from turning over.
On 4 stroke stuff, many times you can't do an accurate compression test. Why? Because many of them have decompression mechanism which reduces the load on the starter. My old F25 showed 75 psi. Guy shows up with his gauge and I just watched him shake his head when he seen 75 show up on his gauge. He questioned it and then I asked him how he was going to calculate what the actual compression was based on the decompressor built into the camshaft. Huh he says? Some Kawasaki engines (bikes mostly) will start/run with a cranking compression of 40 psi. They do it to reduce the load on the kick starter or electric starter. They have to. I've disabled them before and you cannot start them without it, period.
Pappy
Post by Pappy » 05 Sep 2018, 11:01
You cannot go wrong with OTC.
As has been stated the readings will be all over the place between gauges and cranking speed, etc.
Replaceable shrader valves is a good feature to have in one.
Rags2Fishes
Post by Rags2Fishes » 05 Sep 2018, 20:25
Pappy wrote:You cannot go wrong with OTC.
Replaceable Shrader valves is a good feature to have in one.
Do the OTC Compressor Testors come with the shader valve near the entry point of the cylinder? I have some standard tire Shrader valve inserts and can order some new ones. I am also just learning and using my Repair Manual and best advice I can get at this point. I appreciate your reply!
Rags2Fishes
Finger Lakes, NY
Rags2Fishes
Post by Rags2Fishes » 05 Sep 2018, 20:30
I am currently looking at the OTC 5606 Kit. I may try and find a local mechanic who needs some heated shop space and work a deal for shop use.
Anyone else use the OTC 5606 Kit? It looks like a good option.
Rags2Fishes
Finger Lakes, NY
