It is currently 24 Jan 2019, 00:58
SliderG5
 Page 1 of 1 [ 14 posts ]
PostPosted: 07 May 2018, 17:47
How bad is the damage ?Image
Sent from my SM-N950U using Tapatalk
PostPosted: 07 May 2018, 18:03
Are we talking about the small ding on the skeg? Tis' but a scratch :)
PostPosted: 07 May 2018, 19:10
If there's no crack, your good to go. Drop that bad boy back in the drink and power on. We all hit bottom, run aground or hit something submerged at some point, the scratch I see taint nutten, crank her up.
PostPosted: 08 May 2018, 11:57
That's the main reason the skeg is there. It helps protect the prop from damage. It looks like it did its job. If that is all there is you are fine.
PostPosted: 08 May 2018, 15:10
That should have done nothing but add a little character, as long as there are no cracks you should be fine.
PostPosted: 09 May 2018, 11:43
That skeg is basically to protect the prop and more importantly the output shaft from damage. In a way it is nothing more than sacrificial. I ran a boat with no skeg at all for many years.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
PostPosted: 12 May 2018, 19:57
Can we ask how you lost it. Boating stories have great potential!
PostPosted: 13 May 2018, 09:59
I snapped 2-3" off the skeg on an old Suzuki 25 hp on a 13' Boston Whaler when I clipped the side of a huge round rock in the Delaware River. We found the piece but I never had it welded back on because it gave me extra clearance. I've seen a lot of marks on that rock so I know I'm not the only one who hit it. #-o
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
1993 Jetcraft 13' sprint boat with Chevy ZZ3 350 engine and Hamilton 772 jet drive
PostPosted: 13 May 2018, 16:38
How much extra clearance do you get, and extra 1/2"? Remember, the prop isn't that much higher up then the lowest point on that skeg.
PostPosted: 13 May 2018, 20:12
I actually got the full 2-3" of extra clearance because it broke off even with the prop. The skeg really hung down much lower than the prop on that Suzuki motor.
PostPosted: 17 May 2018, 09:57
I wish it was more interesting but I bought the boat and motor like that.
PostPosted: 17 May 2018, 23:06
Was it hamlet or romeo who said "tis merely a flesh wound!"
PostPosted: 17 May 2018, 23:54
I have repaired several that had various degrees of damage to them. Usually they were the result of motor toters that bounced off and the skeg hit the pavement or they backed into something. Surprisingly few were from actual boating incidents. That one there if it were mine at most would get smoothed down and a little paint on it.
PostPosted: 18 May 2018, 19:15
Oh yeah...I seen a guy a few years back pulling a runabout behind his truck. The trim cylinders apparently had leaked down during trailering and the outdrive was dragging the highway. Guy must not have realized it. The skeg was half gone when I seen it....guy promptly got on the interstate and went on with life. Would imagine the prop and remainder of skeg were permanently damaged. A coworker seen it just as I pointed it out and he was hysterically laughing as it was a buddy of his. He tried to call but no answer. I didn't think it was really that funny but I don't know the guy either. Maybe he don't care? Dunno.
My old yamaha is dinged just like the one in the picture...been that way for at least 8 years that I know of (I bought it in '10 and have used it since). To my knowledge, it hurts nothing. But I may weld it up one of these days and then smooth it back down to see if there's any difference in the way it operates, steers, top speed, etc.
Users browsing this forum: Roadrunner and 48 guests
FishonFabrications
