It is currently 20 Oct 2018, 17:40
SwampRunner
 Page 1 of 2 [ 18 posts ]  Go to page 1, 2  Next
 Post subject: 1985 Mercury Classic 50
PostPosted: 27 Aug 2016, 23:08
I purchased a 1985 bass tracker tournament tx 17. The boat has the original 1985 Mercury Classic 50. The motor started fine on muffs at the dealer. I boughte the boat, drove it 2 hours home and took it out on the lake. On the lake it went full throttle for about 3 minutes and lost pressure in the bulb and the motor died. I found out it lost pressure after trying to start it again. I think I have leak somewhere. That should be an easy fix and I am not worried about that. I started it back up and it went to go again and the boat revs but the motor wont go. The propeller spinned in idle but did not notice any speed increase with any more power. The motor sounded different almost pingy? or rattly. Do you think it is the Mercury propeller issue or is it lower unit / motor issue? How do I trouble shoot something like this?
PostPosted: 28 Aug 2016, 09:32
Hopefully someone on TinBoats can help you.
I would suggest you try posting your questions on Iboats.com in the Mercury forum.
PostPosted: 28 Aug 2016, 11:38
I put the motor in forward and the prop clicks one way. When I try to turn it the other way it should spin the flywheel. I just get slippage. I give it some torque and it it clicks / slips.
PostPosted: 28 Aug 2016, 19:04
Yea..buying somebody elses problems..
When I buy used which is most of the time I expect to do a total tear down and reassemble. It works for me cause I do it myself. I could not afford to pay someone to do a total teardown. When one buys used and sometimes new that is usually only half the battle.
Maybe the prop is spinning on the hub..
2 stroke every time I can
4 stroke only when I have to..I don't like boating with my lawn mower
PostPosted: 28 Aug 2016, 22:51
I am feeling cursed. I go to take the lower unit off to see if it is the drive shaft or something in the lower unit. I get the first nut done by the prop. I go to do the two nuts on the sides and I dont have a 16mm wrench. I have the 15mm and the 17mm. Uggg ..... It will have to wait till tomorrow I guess.
PostPosted: 29 Aug 2016, 00:16
I ask again did you check for a spun prop? Mercs will ratchet so...
Just hate to see ya do work if you don't need to...
PostPosted: 29 Aug 2016, 08:37
How do I check for a spun prop? I took the prop off and the splines looked okay. I had a prop that was spun a couple years ago on a 20hp. It would let me idle but then when I went to go faster the engine would rev really high like it was slipping. This time there was a metal clinking / clanking sound to it.
PostPosted: 29 Aug 2016, 12:16
Drained the lower unit oil and there was no oil! Just water in there. I must have burnt up those gears.
PostPosted: 29 Aug 2016, 14:25
You said you bought it from a dealer? I'd get him on the phone first and see what he'll do to set it right.
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
PostPosted: 29 Aug 2016, 16:23
X2
Sent from my LGLS991 using Tapatalk
Online
PostPosted: 29 Aug 2016, 22:22
Dealer has been contacted, but the owner is out elk hunting till next week. So no resolution for a while. It looks like you can get replacement lower units for 350 or so on ebay.
PostPosted: 30 Aug 2016, 08:51
I believe I have a lower unit that will fit that motor if it comes to it - but it's hard to believe that a dealer wasn't aware of that problem and should be responsible.
PostPosted: 02 Sep 2016, 21:30
I went to take the lower unit off and the bolt under the trim tab was completely loose. Would that cause the water to get in to the liwer unit?
PostPosted: 03 Sep 2016, 00:14
No, the only way to access the gear oil is the drain plug. There are seals on the output shaft and the input that either or both have failed. The dealer should have known there was an issue there. No reputable dealer would take a used boat into inventory without checking the lower unit.
PostPosted: 03 Sep 2016, 10:09
Sounds like they may have been in too much of a hurry to get packed and go hunting out West ... loose bolts and no oil, :shock: ouch! Hopefully they'll make it right for you ...
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
Users browsing this forum: Google [Bot] and 61 guests
“ElcoMotorYachts”
