It is currently 16 Feb 2019, 04:57
FishonFabrications
 Page 1 of 1 [ 4 posts ]
PostPosted: 15 Aug 2016, 22:33
My trailer rolled down a hill where I store my boat and the outboard cracked right off. It's a Mariner 9.9 (either 1999 or 2000). I'm hoping someone can tell me what part(s) I broke. It snapped off where the co-steer linkage is and there is a significant amount of grease in the area of the break. Imagemotor mount
Imagemotor mount 2
Imagemotor
Hoping someone can tell me what the part would be called and potentially what it would take for me to fix it.
PostPosted: 15 Aug 2016, 23:37
In Johnson and Evinrude terms the part would be called a steering bracket or swivel bracket.
In order to install a new one you will need to pull both the powerhead and the gearcase then start transferring whatever mounts, etc. you will need.
Problem here is that you are "assuming" that no other parts got damaged. A damaged exhaust housing can, for example, cause premature spline wear in the crank/driveshaft area or down in the waterpump/upper driveshaft bearing housing area. No amount of photos would be good enough to tell this through the internet.
PostPosted: 16 Aug 2016, 00:07
thank you so much. Looks like the bracket itself is about $200USD. I'll need the bearing too, grease, labour. Not looking cheap :( this probably ends my fishing year early
PostPosted: 16 Aug 2016, 13:51
Look for a parts motor. One with a blown power head would be best.
Users browsing this forum: No registered users and 24 guests
Wired2fish
