Transom Wood
1960 yellowboat
Transom Wood
Post by 1960 yellowboat » 01 Jun 2019, 17:43
Is Cedar a good wood to use on transoms?
lckstckn2smknbrls
Re: Transom Wood
Post by lckstckn2smknbrls » 01 Jun 2019, 19:45
I'd recommend BCX grade plywood sealed with Old Timers Formula.
nytebyte
Re: Transom Wood
Post by nytebyte » 01 Jun 2019, 21:52
Cedar is kind of soft so I would go with the bcx sealed.
LDUBS
Re: Transom Wood
Post by LDUBS » 02 Jun 2019, 12:01
Cedar has some rot resistance, but will still need to be sealed if you want it to last. If you wanted solid wood, I would opt for white oak instead of cedar. Again, still need to seal it.
I agree with the previous rec's for BCX sealed. The beauty of BCX plywood, IMO, is that it will be highly stable and is made for exterior use. But again, you still have to seal it.
Have Rod - Will Fish
