It is currently 16 Feb 2019, 09:47 |
Join the free forum or login with your account and the annoying banner goes away |
View unanswered posts | View active topics
Author |
Message |
Sloffie
 Posted: 13 Nov 2018, 20:43 |
I picked up this boat, it needs a good bottom cleaning. I've used typical fiberglass hull cleaner on my ski boat, just not sure it's cool for my aluminum boat with a factory finish. Looking to keep her factory original finish in good shape. So far I've tried simple green, mild clear-coat aluminum auto mag rim cleaner and a 1500 psi pressure washer still looks youckie. Any suggestions??? Thanks Sloffie.
whorrall
 Posted: 13 Nov 2018, 20:50 |
I would try muriatic acid. Dilute it, and use eye protection, gloves, and a respirator. It'll work, just be careful with it.
Weldorthemagnificent
 Posted: 13 Nov 2018, 21:13 |
On bare aluminum I use scotchbrite and vinegar 50/50 with water. On the paint.... maybe it’s time for a refreshing.
JL8Jeff
 Posted: 13 Nov 2018, 21:54 |
Joined: 26 Oct 2013, 14:56 Posts: 582 Location: Ewing, NJ
I've had good luck with Soft Scrub on both aluminum and fiberglass.
_________________ 2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke 1993 Jetcraft 13' sprint boat with Chevy ZZ3 350 engine and Hamilton 772 jet drive
CedarRiverScooter
 Posted: 14 Nov 2018, 09:28 |
Cheap toliet cleaner will work too but don't leave it on there for very long. Wear PPE!
Sloffie
 Posted: 14 Nov 2018, 23:04 |
Thanks all, I'll give a few of them a try.
I'm not a fan of muriatic acid, it's really nasty stuff.
whorrall
 Posted: 15 Nov 2018, 08:37 |
Sloffie wrote: Thanks all, I'll give a few of them a try.
I'm not a fan of muriatic acid, it's really nasty stuff. Ain't that the truth!
MrGiggles
 Posted: 15 Nov 2018, 09:44 |
Joined: 12 Jul 2017, 21:42 Posts: 206 Location: Springfield, MO
I'll second the toilet bowl cleaner. Make sure you wash it good after.
LDUBS
 Posted: 16 Nov 2018, 00:09 |
Joined: 14 Aug 2016, 22:25 Posts: 1861 Location: Clayton California
MrGiggles wrote: I'll second the toilet bowl cleaner. Make sure you wash it good after. Just "flush" it with water! (groan)
_________________ Have Rod - Will Fish
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
