It is currently 15 Feb 2019, 18:19
akmccallumco
 Page 1 of 1 [ 9 posts ]
PostPosted: 11 Nov 2018, 21:46
Im working on my project boat, its rhyan craft bass deluxe. Im doing a mild restoration and want to replace the transom now that i have the boat apart. I just dont see how i can insert new wood without cutting the transom plate out.
If i have to cut i will but if its not necessary i wont.
Theres space from the inside but i doubt i will be able to insert the whole peice through there.
Thanks for you guys help
PostPosted: 12 Nov 2018, 23:22
I don't know the answer to your question. It looks like the transom cap has been removed before.
Here is a link to a previous Rhyan build. Not sure if it is the same boat as yours.
viewtopic.php?f=21&t=6551&start=300&hilit=Rhyan+Craft#p287957
Also, "rotated" versions of your pics:
Have Rod - Will Fish
PostPosted: 13 Nov 2018, 09:20
Im pretty sure ill have to cut, i want to replace it because i dont want to take chances with the motor being so big. My only question is if i cut the cover pieces i still cant get to the whole piece of wood because the gunwhales get in the the way. Would i have to cut all the way to the edge of the boat?
PostPosted: 13 Nov 2018, 12:40
You are going to have to remove the gunwales from what I see in the pictures. Or at least move them aside if possible. Unless that splash well is removable, hard to tell really from the pictures.
PostPosted: 13 Nov 2018, 13:04
The splash guard is not removable. Im thinking i can pop the rivets on the gunwale and remover the last panel on each side and itll let me get to the screws
PostPosted: 14 Nov 2018, 07:50
It's all removable, just depends on how much work you want to get yourself into. Some boats just are not friendly when it comes to rebuilding them.
PostPosted: 14 Nov 2018, 20:31
Figured it out guys, thanks. its not gonna be as big a job as i thought
PostPosted: 15 Nov 2018, 12:54
Post pictures of progress, might help a future project. :D
PostPosted: 16 Nov 2018, 17:40
Still have to take pics of the build, i just finished stripping it down. Its not gonna be a full restoration. Just repaint and new wood.
Anyone have a good video ir tips on making a deck? Not sure if i should make the frame from aluminum or wood.
Users browsing this forum: bikerider, GTS225, Mike461x0 and 102 guests
VinylImagesInc
