Safety chains...you probably already knew this...
Post by richg99 » 01 Nov 2018, 08:55
jasper60103
Post by jasper60103 » 01 Nov 2018, 10:20
Good post.
And the same rule applies if you have safety cables like me.
https://www.youtube.com/watch?v=lYZLCrETRDQ
2018 1648 Grizzly
project motors - '88 Johnson 30 hp, '87 Evinrude 30 hp, '81 Johnson 25 hp
sold - '77 Crestliner Voyager Dlx 16' (semi V), 'Spartan WondeRoll Tilt Trailer
bcbouy
Post by bcbouy » 01 Nov 2018, 15:15
i always thought safety chains were there to stop your trailer from being disengaged from the tow vehicle and becoming an uncontrolled missile and killing other motorists.
if all else fails....stop using all else
GTS225
Post by GTS225 » 01 Nov 2018, 20:09
bcbouy wrote:i always thought safety chains were there to stop your trailer from being disengaged from the tow vehicle and becoming an uncontrolled missile and killing other motorists.
And they do do that. But as long as you have them there, one might as well do something with them that would prevent damage as well. Crossing them, as demonstrated in the video, catches the tongue and coupler before it gets damaged, or worse, caught by a road surface imperfection, thus possibly breaking the chains that are the last failure point.
Roger
jethro
Post by jethro » 02 Nov 2018, 10:13
I have had a trailer pop off the ball before, I sure was glad I had crossed those chains. It helps minimize or eliminate damage to the trailer and tow vehicle. If I had not crossed the chains there would have been too much slack and the trailer tongue would have hit the truck causing who knows what kind of damage. As it was, the event was not more than pulling over and hooking it back onto the ball. And cleaning my shorts :oops:
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
reelfunnm
Post by reelfunnm » 02 Nov 2018, 11:28
I had mine come off once. Crossing the chains and having the spare on the tongue kept it from being a disaster. Only damage was bald spot on spare.
DaleH
Post by DaleH » 02 Nov 2018, 11:47
Don't youse guys lock your trailer couplers down? I do ... and I see no way that a ball could ever pop out ... as the 'cup' or locking part that rotates up underneath the ball won't allow it to pass by.
#4 Procraft SV14
GYPSY400
Re: Safety chains...you probably already knew this...
Post by GYPSY400 » 02 Nov 2018, 12:22
DaleH wrote:Don't youse guys lock your trailer couplers down? I do ... and I see no way that a ball could ever pop out ... as the 'cup' or locking part that rotates up underneath the ball won't allow it to pass by.
The only way I see it coming apart is that the coupler is not adjusted properly or an external excessive force acts upon the trailer... but it does happen
Sent from my SM-G903W using Tapatalk
jasper60103
Post by jasper60103 » 02 Nov 2018, 12:39
I pad lock mine.
2018 1648 Grizzly
Post by richg99 » 02 Nov 2018, 18:32
Back when I had my "pop-off" I had one of those old-fashioned Screw-Crank-Down couplers. Even that wouldn't have come off, except that I was dealing with having both wrists re-built by surgery.
The surgery hadn't happened yet. I simply didn't have the wrist strength to crank the coupler down hard enough. My Bad!
The Flip-lever type can be adjusted, correctly or incorrectly. I've had them come almost too tight to fit, and also too loose to do their job. The big nut underneath has to be set right.
rich
nccatfisher
Post by nccatfisher » 02 Nov 2018, 19:03
If the part that actually couples, the part that cams over breaks, locking or not it will pop off. I do quite a bit of welding and I have had several come in my shop wanting that particular piece welded. I always refuse to weld them. I tell them it would be better and not that much more expensive to replace the whole coupler.
bcbouy
Post by bcbouy » 02 Nov 2018, 20:58
quite a few years ago,i forgot to switch my 1 7/8 to my 2 and you can guess what happened.now it's 1 size for everything.
LDUBS
Post by LDUBS » 02 Nov 2018, 23:36
I did already know about crossing the chains below the hitch. But after watching the video I realized my safety chains have too much slop. I need to shorten them some.
Thanks for posting.
Have Rod - Will Fish
Stumpalump
Post by Stumpalump » 03 Nov 2018, 00:01
Out West they look for chains dragging on the ground. They start forest fires and you will get a ticket for it.
1991 18' Valco Bayrunner Evenrude 48 SPL
Arizona
GTS225
Post by GTS225 » 03 Nov 2018, 08:04
Stumpalump wrote:Out West they look for chains dragging on the ground. They start forest fires and you will get a ticket for it.
I think I'm going to remain skeptical about this.
A) How is anybody going to prove this happens?
B) It seems to me that a spark from a dragging chain is much too short-lived to make it to anything combustible, let alone actually heat it up enough to ignite.
But then, there's many government types that don't want me to confuse them with common sense or facts.
Roger
