jack plate
turbotodd
jack plate
Post by turbotodd » 20 Sep 2018, 23:16
I've decided to try a home-made manual jack plate. 4" angle aluminum, some stainless fasteners, and some scrap oak plywood glued together to make the motor board. I have the concept down and have everything cut and put together as a mockup. My question is.....on the wood. What do you guys do to seal the wood so that it doesn't soak up water? I will be trying it with my little 25 yamaha on war eagle boat, if that makes any difference.
surfman
jack plate
Post by surfman » 21 Sep 2018, 06:54
You can seal it with epoxy, after you drill all your holes make sure you get the epoxy into them as well, then you will want to paint over the epoxy with a good enamel paint. Epoxy doesn't hold up well with UV exposure and will get dull and flat.
BillPlayfoot
jack plate
Post by BillPlayfoot » 22 Sep 2018, 06:19
I use the West System epoxy because it is more flexible. Then I spray polyurethane colour paint or clear coat depending on if the wood is seen or not.
lckstckn2smknbrls
jack plate
Post by lckstckn2smknbrls » 24 Sep 2018, 21:14
Is the oak plywood made with waterproof glue?
I'd recommend the Old Timers formula to seal the plywood.
turbotodd
jack plate
Post by turbotodd » 24 Sep 2018, 22:12
lckstckn2smknbrls wrote:Is the oak plywood made with waterproof glue?
Do not know. It was left over material from a cabinet shop. Red oak. Harder than hammered you know what; hard to even cut the stuff. What is the "old timers formula"?
lckstckn2smknbrls
jack plate
Post by lckstckn2smknbrls » 24 Sep 2018, 22:56
It's a home made mix of mineral spirts, spar varnish or spar urethane and Boiled linseed oil.
Do search on the site.
If the plywood is not made with waterproof glue it's going to delaminate no matter how well it's sealed.
LDUBS
jack plate
Post by LDUBS » 25 Sep 2018, 01:20
Typical cabinet grade hardwood ply is not going to use waterproof glue. I don't want to be a downer, but would not use it on a transom (sorry). :(
Have Rod - Will Fish
