scotty rod holder's?
ignantmike
Post by ignantmike » 23 Jul 2018, 17:51
hello, so a got 2 rod holders from a neighbor....scotty brand with the rail adapter's....the boat I have is a '74 mirrocraft 14 footer....with the rolled over gunnel's.....I know the easiest thing is to buy the clamp mount's....but, I have a lot of old plumbing pipe and elbow's and was thinking this would work?......just not sure how to attach it to the boat's gunnel's?......any idea's???...thank's
GYPSY400
Re: scotty rod holder's?
Post by GYPSY400 » 23 Jul 2018, 19:44
Just buy the proper bases for what you need.. either side mount to the hull below the gunnel or top mount to the bench
Sent from my SM-G903W using Tapatalk
nerdtastic
Post by nerdtastic » 24 Jul 2018, 11:16
Yeah the side mounts are cheap and they just work right. So much easier than trying to piece something together.
Sent from my SM-G892A using Tapatalk
LDUBS
Post by LDUBS » 24 Jul 2018, 16:21
x2 on the Scotty side mounts. When you say you have a rounded gunnel, I expect that you will need a spacer between the side mount and the hull. Reason is the radius of the gunnel will interfere with inserting the rod holder into the side mount. Not a big deal. Almost anything will work. Easiest might be to cut a piece off of a cutting board. Depending on your living situation, you might have to pretend you don't know why the cutting board seems smaller.
Have Rod - Will Fish
DaleH
Post by DaleH » 24 Jul 2018, 17:48
LDUBS wrote:Depending on your living situation, you might have to pretend you don't know why the cutting board seems smaller.
Bad boy ... I’m a tellin’ Mrs LDubs, haha!
#4 Procraft SV14
LDUBS
Post by LDUBS » 24 Jul 2018, 23:21
Too late Dale. Mrs LDubs said she would like an excuse to shop for new kitchen stuff. :?
jethro
Post by jethro » 25 Jul 2018, 08:21
Scotty makes no end of mounts for their system. Rail mounts, flush mounts, clamps, offsets, etc. I have a bunch of scotty rod holders, they are awesome.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
Doc Arroyo
Post by Doc Arroyo » 26 Jul 2018, 13:45
My gunnel is not the perect size for the base, and I didn't want them above it. It interferes with the boat cover. So, an aluminum angle provides enough vertical meat to attach to, and does not add much height.
Sometimes the little simple modifications are the best.
[img]
LDUBS
Post by LDUBS » 26 Jul 2018, 23:43
Doc Arroyo, looks like an ideal solution to me. Perfect for your application, IMO.
