It is currently 19 Apr 2019, 02:48
SliderG5
 Page 1 of 1 [ 4 posts ]
 Post subject: Blue Star boat
PostPosted: 21 Aug 2017, 11:58
Does anyone happen to have a circa early 60's Blue Star aluminum fishing/utility boat? Mine is missing the bow plate/cover. Mine is missing whatever it should have come from the factory, and I would like to restore my missing bow plate to something similar to that. Or, maybe someone has a picture of what it looked like from the factory.
Thanks to anyone who might be able to assist.
Kyle
PostPosted: 21 Aug 2017, 12:23
Kyle - can you post a photo of what you have now ?
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 21 Aug 2017, 20:19
The picture with the plywood is how it was when I bought it. The other two are as it is now; looking at the bow from the stern, and the other picture was taken as I was trying to bend an aluminum sheet template around the curve of the gunwales (if I am using and spelling the term correctly.)
There is an inordinate number of holes drilled through the gunwales at the bow end. The plywood was screwed through them, but they may have been there to attach an extended bow cover ...not sure.
Thanks for asking.
PostPosted: 21 Aug 2017, 21:04
what kind of bow deck would you like to have ?
you have several options - depending on how you will
be using the boat the most often. plus will you be using a tiller or remote steer.
when I removed the lid off my Crestliner, it looked just like yours now.
full of holes where it had been modified over the years.
I filled both gunnels with spray foam so I could patch the holes that were not needed.
this gives you a foundation for the epoxy filler as well as a small bit of flotation.
the top deck lid is pop-riveted flush with the gunnels - it does not fold over.
and is reinforced from underneath. there are several good examples of bow decks in this forum.
Users browsing this forum: Majestic-12 [Bot] and 82 guests
FishonFabrications
