It is currently 20 Mar 2019, 11:51
Wired2fish
 Page 1 of 2 [ 19 posts ]  Go to page 1, 2  Next
 Post subject: RHINO LINING INTERIOR
PostPosted: 05 Aug 2017, 18:46
Hey I just traded a rifle for a 1986 Bass Tracker tournament v-17 the boat is in fair shape. Major problem is the transom is needing replaced. I have a good grasp of wood working and mechanics so I don't think that there will be a problem with that. The carpeting in the boat is rotten, I'm thinking of replacing it with Rhino Lining, My buddy does it professionally and he owes me big time for some electrical work. I guess my question is has anybody seen it done before? The wood under the carpet now is still in fair shape, only one little piece appears to need replacement.
PostPosted: 05 Aug 2017, 18:51
That stuff weighs a ton
1244 Atchafalaya Outdoor Designs W/ 12hp Copperhead
PostPosted: 05 Aug 2017, 19:11
welcome aboard Gunner.
put some thought into the Rhino Liner.
once it is on - it is on forEVER.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 05 Aug 2017, 19:19
I don't think that the liner can weigh much more than the carpet a glue will, I think that it would hold up better to weather than carpet would and as far as permanents I'm looking more towards utility and endurance than cosmetics. Do you really think that the liner would weigh much more than the carpet?
PostPosted: 05 Aug 2017, 19:31
what do you plan to spray the liner on ??
the aluminum hull or wood decking ?
I was thinking you wanted to spray the hull - which is not recommended.
as for spraying a plywood deck, I would say go for it.
your boat = your call
come back after it's done - we would like to hear your opinion (pro or con).
oh - and I doubt very seriously if anyone has ever actually compared the weight
of liner vs carpet...... on the automotive forums, it is agreed upon that the liner
adds between 40 and 60 pounds of weight to a standard 8ft pickup truck bed.
PostPosted: 05 Aug 2017, 20:07
Ya just planing on spraying the wood deck. Ya so i'm thinking that it not much more than the glue/carpet would weigh. I have been reading on other forums about it now that a weight issue was raised and it seems that it's not much of a big deal. I am looking forward to the project. I understand there was a thread on repairing the transom a tutorial I haven't been able to find it can someone link it?
PostPosted: 05 Aug 2017, 20:56
this is an article that I wrote awhile back - for a very heavy duty transom
for 35hp or larger motors. for something 25hp or smaller, just use TiteBond III wood glue
instead of epoxy and don't use fiberglass cloth.
https://www.tinboats.net/how-to-build-a-transom/
PostPosted: 05 Aug 2017, 21:08
If you look at the truck pages people are talking 70-80lbs for a truck bed worth....
PostPosted: 06 Aug 2017, 00:39
I have a 06 PT175 that is 17'3" in length and a 83" beam. I checked in to rhino liner for the whole inside. The thinnest that they would do, and still warranty it. Would add right at 85 to 95 lbs. to the boat.
So I would look into Tuff Coat. It's a roll on type paint with rubber in it for a great nonskid texture. Made for boat decks. And comes in a lot of colors also.
PostPosted: 06 Aug 2017, 00:51
X2 On the Tuff Coat, very durable.
1973 Hewescraft Big Fisherman 14
1980 Johnson 15
“I love being alive and will be the best man I possibly can. I will seek knowledge from those wiser than me and try to teach those who wish to learn from me.” Duane Allman
PostPosted: 14 Aug 2017, 11:18
I am currently restoring a 98 v17 and using tuff coat. I have torn the boat down and just cut a new transom for it. Not a hard job but in the V17 you have to cut the corners after taking off the cap to pull the old one out. Now that it is cooling off I will be putting more time into it.
PostPosted: 15 Aug 2017, 14:31
I'm confused. If you can do a bedliner with about 2 gallons of Herculiner, how does a Rhino-Liner weigh 70-80 lbs.? After drying and curing?
PostPosted: 16 Aug 2017, 14:08
Thats my question to. But that's what they told me. Something to do with thickness and a much more solid material.
PostPosted: 16 Aug 2017, 17:54
yeah - back to school I suppose.
if a gallon of coating weighs 12 pounds, and it is applied to a surface,
obviously, the solvent and carrier evaporates out - thus making the
coating lighter - not heavier.
so - if it takes 5 gallons to do a big truck bed, the initial application would
add 60 pounds - - - with evaporation of the liquids, I am sure it would
weigh less - not more.
~ correct ~ ????
PostPosted: 18 Aug 2017, 00:46
Yes, I believe so to. But how much evaporation occurs. To something that is at its full size when it is applied. And the only thing that really happens it it hardens up. Just asking, for my own curiosity.
Users browsing this forum: EAnton, Google [Bot], Scott F, uttexas and 117 guests
Wired2fish
