https://www.forum.tinboats.net/
Transom bracing?
https://www.forum.tinboats.net/viewtopic.php?f=3&t=41377
Page 1 of 1
Author:  Texas Prowler [ 30 Jul 2016, 15:32 ]
Post subject:  Transom bracing?
Hey guys since I've converted my short shaft transom to long. I've questioned the need to replace or add extra bracing. I'm really wondering if the center hull brace needs to be bigger/ more tall to support more of the transom. I could have a shop fab one that's better suited for the job. I'll be using a 73 Johnson 50hp if that helps. Its one heavy beast that's only picked up by an engine hoist. Any suggestions/ advice are appreciated. Thanks!
I've added aluminum square tube thus far not finish bolting it yet tho...
Author:  lckstckn2smknbrls [ 30 Jul 2016, 18:50 ]
You could use 2 pieces of aluminum angle bolted to the original knee brace.
Author:  Texas Prowler [ 30 Jul 2016, 21:25 ]
Post subject:  Re: Transom bracing?
Sounds like a good idea. And simple as well
Sent from my LGLS991 using Tapatalk
Author:  JMichael [ 31 Jul 2016, 10:40 ]
Does it have gussets in the corners? I couldn't seen any in the pics.
Author:  Texas Prowler [ 31 Jul 2016, 11:06 ]
Unfortunately it didn't come with any from the factory. Image
There's wood along the gunwales front to back.
Author:  JMichael [ 01 Aug 2016, 10:28 ]
Adding some gussets would be my next step to strengthen the transom if it were mine.
Author:  Texas Prowler [ 01 Aug 2016, 12:09 ]
Sounds good to me. I guess I'll have to see about having a shop fab some up.
Page 1 of 1 All times are UTC - 5 hours [ DST ]
Powered by phpBB® Forum Software © phpBB Group
http://www.phpbb.com/
