Poly Marine Livewell Tank Mod
AnglerC
Post by AnglerC » 21 May 2016, 17:11
I need to mod a livewell tank that came out of a Lund. It's 8" too long. I plan to chop it and glue the end back on with epoxy. Has anyone ever attempted this? Any tips, tricks or thoughts would be greatly appreciated.
Buckethead
Re: Poly Marine Livewell Tank Mod
Post by Buckethead » 21 May 2016, 23:23
Angler, I didn't shorten a tank but I removed a bench seat from my boat, flipped it upside down and made a 21 gallon livewell out of it. I'll try to post a link to my build so you can see how I did it. It wasn't hard and it still holds water today.
Buckethead
Post by Buckethead » 21 May 2016, 23:25
Buckethead's 1974 Duracraft 1720
http://forum.tinboats.net/viewtopic.php?t=26781
Johnny
Post by Johnny » 22 May 2016, 09:39
in my world, most anything can be cut down to make
it longer or shorter - as long as it has the proper support
on the seam...... some 1 to 2" strap of something or other
screwed, riveted or glued over the seam for reinforcement.
50 or more pounds pounding in a boat ride could rupture
even the best seam job...... support support support.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
Ebug
Post by Ebug » 22 May 2016, 11:45
If I were tackling that project I would start with calling a local plastic material supplier to ask if they weld plastic....or have a customer that does. Another source for welding plastic would be a dedicated kayak dealer near you. Most all of them either weld plastic or have a contact that will.
A weld joint is going to be far stronger than epoxy on a flexible material. Not saying it can't be done...just how I would do it.
Just an option.
AnglerC
Post by AnglerC » 22 May 2016, 16:38
Thanks guys. All helpful info. I'm going to do some looking to see if I could get it welded. That seems the best alternative. However I plan to frame it in and build the deck around it. That should afford me plenty of support.
Johnny
Post by Johnny » 23 May 2016, 11:19
Angler, since you will theoretically have 8" of scrap
poly material left over - why not experiment with
some of it to see what will work for your situation.
For instance: heating a large chisel or screwdriver
with a torch and heat welding two pieces together.
Soldering Iron with whatever blade that works for you.
Chemical Adhesive that will melt/weld/fuse the material together
such as Plastic Solvent Adhesive. (there are several brands).
and still use a splice of some kind to reinforce the seam.
Since this will most likely be a one time deal, there
is not much reason to put a lot of money into the more
expensive tools or equipment.
jus my Dos Centavos
Post by richg99 » 23 May 2016, 14:13
Epoxy won't hold if the plastic is the same stuff that kayaks are made out of..which I think it is.
Plastic welding will be the right way. There are tons of YouTube videos showing how to do it. I sealed some holes in a plastic tub with my soldering iron. Check this video out. There are many.
https://www.youtube.com/watch?v=kibSo9JqWyo
onthewater102
Post by onthewater102 » 23 May 2016, 15:39
Polyethylene and polypropylene plastics are notorious for not allowing adhesives to bind to them & require they be welded. Sight unseen I'd bet one of these is the type of plastic that tank will have been made from & I'd be another +1 to suggesting you get it sonic welded.
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
AnglerC
Post by AnglerC » 23 May 2016, 22:00
Youtube has a ton of these vids on welding plastic. Harbor Freight even sells a welder. Going to do some more research and see which is the better route to go. I'll keep you all posted.
AnglerC
Post by AnglerC » 04 Jun 2016, 14:32
Alright. As promised I am going to post my progress on my tank mod... So here we go. Pix to come.
AnglerC
Post by AnglerC » 04 Jun 2016, 14:45
This is the tank in question. I love this tank. It's big. Beautiful...And will hold all my bait and several walleyes... I was certain it would fit...
AnglerC
Post by AnglerC » 04 Jun 2016, 14:48
Missed it by THAT much...
AnglerC
Post by AnglerC » 04 Jun 2016, 14:54
I struggled cutting this beauty.... I stood there several minutes with saw in hand making sure I truly wanted to cut into a perfectly tank. I worked though it and was able to make my cuts.
AnglerC
Post by AnglerC » 04 Jun 2016, 14:56
Three pieces. Bait well, Live well and end cap.
