It is currently 17 Feb 2019, 18:57 |
Join the free forum or login with your account and the annoying banner goes away |
View unanswered posts | View active topics
Author |
Message |
Jersey Joe
 Posted: 27 Jul 2014, 12:58 |
Hello All...I'm a new member here, and novice boater. I'm looking for a dual purpose aluminum boat for pulling the kids around and also bay fishing/crabbing and such. I think I'm settled on an open bow like the Starcraft Superfisherman or other brands like that. I've read a lot on here about replacing rivets and such when rehabbing boats. When I'm looking at a used boat, how can I tell if it needs rivets replaced? Will they just be loose to the touch? Any suggestions will be appreciated.
JJ
El_Guapo
 Posted: 27 Jul 2014, 15:48 |
Joined: 26 Apr 2014, 15:06 Posts: 48 Location: Morenci, AZ
There's multiple ways to see if rivets need replaced. The most obvious is the visual "Is it there?" test, followed by the mechanical "Is it loose?" test.
Then you're going to want to look for corrosion on the insides, and shiny spots around the heads indicating movement. The definitive test is to fill the hull with water and watch for leaks. In my own experiences with aluminum boats, I've never found more than half a dozen leaky rivets on a hull. This being the current USS Rustoleum project, where the two prior tin boats tied at 3.
Natedog57
 Posted: 27 Jul 2014, 22:45 |
Joined: 18 Jul 2014, 15:55 Posts: 35 Location: Central FL
I agree that the best way to ID loose rivets is with a water test, which if you're buying a boat/motor/trailer combo hopefully you can do. If possible, keep it in the water for 30 min or so and see how much water it has taken on.
When you tap rivets with a tool, or your fingernail, good tight ones sound similar to the sheet aluminum, but loose ones will have a slight "tap" or "ting" noise/vibration. You can't check all the rivets via this method, but a few here or there.
Sometimes loose rivets can be reset, or if they're already pretty flared out, they'll need to be drilled out and replaced.
Dunno where you're located, but I've seen many boats in various stages of disrepair, from few to many repairs needed. IMHO repairs can be done (rivets replaced/reset), it's just about you (the buyer) making an informed purchase and buying what you want (a boat turn key or project).
Good luck with the hunt!
PSG-1
 Posted: 28 Jul 2014, 08:05 |
Joined: 15 Sep 2011, 08:48 Posts: 2248 Location: South Carolina (redneck riviera)
Sometimes when they are really bad you can see it visually as you're underway. I once had a riveted bottom 14' Dura Craft that I had used to jump waves in the ocean, along with all the other abuse I put on it, such as running the rough water of the ICW, running aground on oyster beds, etc. The rivets leaked so badly, anytime the boat was underway, they shot water a few inches high like miniature sprinklers.  Best way to find leaks in a boat....with the boat on the trailer and the drain plug in place, fill it with about 4-6" of water, and start looking underneath. They will be real obvious.
_________________ ALUMA-JET project: viewtopic.php?f=21&t=22023
Fishing, jet skiing, target shooting, jet-boating, and even a little oyster harvesting with Larry The Cable Guy. Watch it all right here:
http://www.youtube.com/user/HKPSG1Shooter?feature=mhee
tonynoriega
 Posted: 28 Jul 2014, 11:23 |
Joined: 08 Aug 2012, 12:31 Posts: 252 Location: Boise, ID
I second the Water Test method.
I filled my 16' with enough water to take a bath... dried up any splashing around on the ground ( in the garage). Wiped the outside dry, and just waited.
I ended up replacing about 20-25 rivets that were weeping, some actually dripping, and others had a drip every minute or so....
I don't regret it one bit.
_________________ 1952 16' AlumaCraft Model K - First boat!
Jersey Joe
 Posted: 28 Jul 2014, 22:52 |
Gents...Thanks for the tips! Time to hit Craigslist again. I'm hoping more become available as the summer winds down.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
