It is currently 17 Feb 2019, 18:30
 Page 1 of 1 [ 5 posts ]
 Post subject: Lowe Paint Question
PostPosted: 04 Nov 2012, 15:54
I want to touch up or re-paint a 2002 Lowe Roughneck. Can I match the paint for touch up or will I have to re-paint the whole boat? Does Lowe sell paint or is there a better paint to use? Thanks, ET :?
Feel free to stop by my Texas Outdoors Blog and leave a comment
http://wildedtx.blogspot.com/
PostPosted: 04 Nov 2012, 17:17
As far as matching there are tools used by body shops that can match it correctly. As far as which paint someone with more expieriance will have to help you there.
PostPosted: 04 Nov 2012, 18:30
You can buy Lowe spray paint from any distributor.
I used to run a body shop and I've told more customers than I can remember that "you can't match faded."
If you touch it up, you're going to see it.
If you are looking for a really good paint job, scuff the entire boat, prime any bare aluminum with etching primer, sand everything one last time, wash with degreaser (Dawn dish detergent works well) wipe down with thinner to remove any contaminates (fingerprints) or dust from sanding, wipe with tac cloth and spray or roll and tip.
If you do not have a Lowe distributor in your area, check out Parkers Duck Boat paint. Their green is good and flat and dries out nice. It's also easy on the pocketbook at about $15 per quart which should be plenty to do 2 coats on the outside.
PostPosted: 04 Nov 2012, 18:44
Thank you for the expert information. ET
PostPosted: 04 Nov 2012, 20:53
As I was reminded in a previous post/thread asking about touch up paint, dings give a boat character, etc... I'm rationalizing along those lines and leaving my Lowe as is... :)
2000 Lowe 170 w Johnson 70hp, MinnKota Maxxum 24v TM, PP Micro Anchor, Nauticus Smart Tabs SX
Users browsing this forum: Bing [Bot], DMack, MrGiggles, Tango66 and 110 guests
mud-skipper
