It is currently 24 Apr 2019, 02:16
Wired2fish
 Page 1 of 1 [ 10 posts ]
 Post subject: Transom Riser
PostPosted: 10 Feb 2019, 14:06
I have a short shaft Johnson 15 and a short transom. Cav plate still 1 1/2" below the hull. I have a chance to buy a static mount kicker bracket for cheap. Could I use just the poly mounting board and bolt it outside the transom to get the desired rise. The bracket is rated to 15hp. The poly board would result in a 2" setback. Good idea or no?
1973 Hewescraft Big Fisherman 14
1980 Johnson 15
“I love being alive and will be the best man I possibly can. I will seek knowledge from those wiser than me and try to teach those who wish to learn from me.” Duane Allman
PostPosted: 10 Feb 2019, 15:04
i don't see any reason why it wouldn't work.if it were any higher hp or heavier 4 stroke i'd consider a mechanical jackplate,however i personally would not trailer it in the lifted position. t-h marine makes a small jackplate for around $100.bass pro as well.
if all else fails....stop using all else
PostPosted: 11 Feb 2019, 02:17
Not trying to be a wise guy here. What will you gain by doing this?
Have Rod - Will Fish
PostPosted: 11 Feb 2019, 09:06
My motor is a longer short shaft and I run a T&H mini jacker, It's great.
Online
PostPosted: 11 Feb 2019, 09:53
i got one off of a member here. worked great! solved my issues with porposing and added more speed. also would get up on plane faster.
PostPosted: 11 Feb 2019, 17:22
I used 1/4" aluminum angle for mine & got about 4" of setback in the process.
LDUBS - it gains you a little top end speed, a little acceleration and (done by yourself) doesn't cost much.
I have a marriage license and a fishing license, but I only carry one in my wallet.
For Sale - Custom Hand Tied Jigs, Bladed Jigs,Custom Rods
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
1985 Bass Tracker III - Restoration w/ 1988 Mercury 60hp
PostPosted: 12 Feb 2019, 01:33
some also say that a little setback also helps a little with the handling,but with a 15 it probably wouldn't be noticeable.
PostPosted: 12 Feb 2019, 02:12
I think if anything my 1436 lost a bit of handling vs having the prob burried another 2.5 inches in the water. I noticed I can blow my prop out cutting turns too hard now that I could make with ease in the past.
PostPosted: 12 Feb 2019, 11:04
that's where power trim or the lack thereof comes into play.with a 15 hp you have limitations.my 25 ss tilller tohatsu would cavitate in tight turns if i didn't adjust the trim accordingly.
PostPosted: 13 Feb 2019, 16:57
That's phase 2 of the riser build slated for this year...hopefully successfully adding a power trim adjustment. Until then you're right, I'm stuck with the trim at a fixed position.
Users browsing this forum: Google [Bot] and 46 guests
