It is currently 20 Jan 2019, 19:37
FishonFabrications
 Page 3 of 3 [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: 10 Sep 2017, 13:56
I'm putting a floor in my weldbilt 1548...how did the plywood work out and what kind did you use? Did you carpet it?
PostPosted: 17 Sep 2017, 18:07
Cut out the center seat...plan to use to store batteries and other storage and electrical...
and I'll add as much foam board and other foam as I can fit!!!!
Also cut the rear seat for gas can storage and got some of the framing done in the stern
Framing is almost done...only a few more supports and ready for plywood and foam
just in case you were wondering....The transom board and transom cap are cut... they need to be sealed and painted. And then I'll have everything welded back in place!
Travis
Boat- Work in Progress... Lowe 1436
Trailer - Homemade... need work
Truck - 06 Dodge RAM 1500
PostPosted: 17 Sep 2017, 18:11
Basically I still need to seal all the plywood and I plan to cover with carpet.
I used 1/2 CDX exterior plywood... pretty easy to work with.
I'll keep you posted once I get everything wrapped up... this project seems to never end!
Travis
PostPosted: 02 Oct 2017, 20:45
Well just about all the plywood is cut....
And I got the seat mounts install... here's the one for the front
Need to get hatches cut and seal everything. And I need to try and get the transom done and welded.
Travis
PostPosted: 22 Oct 2017, 16:13
I've sealed all the plywood with West Marine Epoxy Resin.... can anyone tell me if it needs to be scuffed up prior to applying the marine carpet glue?
Travis
PostPosted: 22 Nov 2017, 10:16
Got the carpet to cover the plywood.... guess I have all winter to get that done now.
Been hunting and haven't had a chance to do much with the boat.
Travis
PostPosted: 07 May 2018, 08:03
Weather is finally warm... been working on the boat some over the past few weeks. I'll post some pictures of the recent progress.
Travis
PostPosted: 12 May 2018, 10:55
Got started on the wiring...a few weeks ago.
The transom board is ready to install and I plan to have all the welding done next week.
wrapped all the plywood with carpet...
Going to finish up the carpet and wiring in the next week or so...
Travis
PostPosted: 12 May 2018, 11:39
A few more pictures of the progress...
Center section with hatches... center hatch is where batteries will be... other 2 will be storage for whatever...
I got the speakers installed... the Bluetooth radio will be added soon.
Travis
PostPosted: 20 May 2018, 11:29
Had the transom cap and corner brackets welded back on...just need to bolt it all back together and slap on some paint.
Now that the monsoon has finally stopped here in Virginia... I should be able to get back at it.
Travis
PostPosted: 21 May 2018, 12:55
Looking good there man cant wait to get me one to play with.
PostPosted: 27 May 2018, 18:36
Those 3 hatches in the front are lovely!
Can you estimate your total costs to this point ?
PostPosted: 02 Jun 2018, 11:46
Thanks... that's probably something I really don't want to think about. :)
Everything together... maybe $400-500... not counting the new bow mount trolling motor
All Aluminum + screws and rivets
plywood and styrofoam
epoxy resin
carpet and glue and staples
new seats and seat mounts
all wiring.... switch panel, fuse block, bus bar, and extra electronics :D
the list gets too long...
Travis
PostPosted: 11 Aug 2018, 11:05
Front deck build
Travis
Users browsing this forum: Superlucky and 75 guests
FishonFabrications
