It is currently 16 Feb 2019, 06:29
FishonFabrications
 Page 1 of 3 [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: 1660 Mod V Hull Project
PostPosted: 25 Jul 2016, 22:09
I recently bought a moderate v hull boat. I originally thought it was aluminium, but it's much heavier than it should be and the guy who I stored my boat with thinks that its galvanized steel. In any case, it's a huge step up space wise from my old 1236.
Here is the boat how I first got it. I purchased it from a mechanic that painted and rewired the trailer. I think he also repainted the outside of the boat.
I took the old 9.9 off my 12 footer for now. I will eventually upgrade to a 25+ hp tiller.
The first thing I did to the boat was install a seat and an old donated bow mount trolling motor.
The next thing I did was rip out the two middle bench seats. They had low quality, aged and deteriorated flotation foam. I will be adding a lot more than what the boat had.
I placed 4 foot aluminum angle along the ribs to get an idea of what I'm up against. I paid way too much for the aluminum at HD. Found 1/2" square aluminum tubes that are 9 1/2' long locally for $5. Hoping they're strong enough to be used structurally.
I've been immersed in project build threads here for the past month or so and I've decided to take elements from many of the different amazing builds here and on YouTube. Unfortunately I lack the 'toolsy' skills that many here possess, but I'm taking the plunge anyways.
My plan includes the following (random scatter brained order):
1. Nautolex vinyl covering everything.
2. Decent gunwales with rod locker on one side, maybe both. Storage on one side of no second rod locker.
3. Will be spending the extra money for a lock for the rod locker latch, slam latches for everything else, trolling motor plug for future upgrades.
4. Aluminum frame with plywood as the structure.
5. U shaped structure to operate the tiller.
6. One seat centre rear
7. Elevated front deck level with gunwales.
8. Seat on front deck.
9. Flotation foam under the aluminum frame like in this boat as well as in every available space (picture borrowed from tinboats.net):
10. I'd love to put a live well in if space permits, but I'm pushing it. If I can it will be half of the rear of the front deck.
11. Emergency gear storage at the very top of the front deck.
12. Winch type anchor hanging on the front of the boat.
13. Enclosure for the gas can, with hose and fuel fill tube so I can fill up gas directly.
What I'm really hoping for is to hear where my plans are flawed. I'm really not experienced with any skilled building. Adding to my challenge is the fact the boat is 2 hours away and I don't have a great work area as of yet. Thanks for the long read. Hoping for advice.
PostPosted: 25 Jul 2016, 22:48
Welcome to da Bayou, Jiggly
test the hull with a magnet
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 25 Jul 2016, 23:56
will do!
PostPosted: 26 Jul 2016, 08:00
Looks good! I'd forget about enclosing the fuel tank, you may find it more trouble to rig up properly than it's worth ...
Nothing like being able to slide out an empty tank from under the seat and then grabbing a fuel one from the garage or shed and heading out fishing ...
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
PostPosted: 26 Jul 2016, 10:02
makes sense and saves money.
I also found out that the boat is a Spectrum, which appear to have been made by tracker.
PostPosted: 27 Jul 2016, 13:54
Another strike against the internal fuel tank - assuming you're using the foam board insulation from most big box home improvement stores if you spill gas filling your tank you're likely going to have it dissolve your foam into sticky goo.
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
PostPosted: 04 Aug 2016, 03:49
Got frustrated by the lack of fishing and threw in a 4x8 pressure treated plywood board sitting on unsecured aluminum tubing (and a tackle bag and a battery ). Will get back to proper installation in two weeks Image
PostPosted: 04 Aug 2016, 09:09
If it is an aluminum hull you don't want to use pressure treated wood. The copper used in the wood will react badly with aluminum.
PostPosted: 04 Aug 2016, 09:28
ive read this before. What if I vinyl it? Does that help?
PostPosted: 04 Aug 2016, 09:32
When the wood gets wet the copper will leach out and where the water goes the copper will go.
PostPosted: 04 Aug 2016, 09:34
gotcha. Was well worth it for the day. I'll pull the board out asap. Will it cause damage if left in for a couple days?
PostPosted: 04 Aug 2016, 09:44
I'd do it for a day or 3 but not for long especially if the wood is new and the treatment is wet.
PostPosted: 27 Sep 2016, 20:54
So I started the thread off explaining that I'm not "toolsy" and the results support my claim.
Finding a place to work on the boat has been challenging, but my brother in law let me use his garage for a very short time, so I've been rushing to get her functional for some fall bassin'
I framed the floor using 1/2" 1/16 aluminum tubing that I sourced cheap on Kijiji. It's all held together with low grade fasteners and L brackets. It's not pretty and it's probably not going to be great long term. If I get two years outta her like this I'm happy.
I used black silicone to seal the rivets. I'm saving the 5200 to seal all the exterior below-the-waterline holes I drilled. Image
Sealed rivets
Exterior screws....how bad of an idea is this?
Where I'm screwing into
Wood in to mark off the path of the aluminum angle cross bracing.
Framing in the final stages of completion.
PostPosted: 28 Sep 2016, 08:10
Those screws are a BAD idea. They will work loose. Drill thru with 3/16" bit and re-fasten with solid aluminum rivets.
PostPosted: 28 Sep 2016, 08:23
Silicone has an acid in it that is bad for aluminum.
Users browsing this forum: 787, Google Adsense [Bot] and 34 guests
akmccallumco
